Tool Talk Discussion Forum
Pressure washer
Jim-IL
04-18-2005 15:32:36
How good does a pressure washer work on vinyl siding? Is there a danger of damage with one? My house is covered with green mold or mildew and I'd like to get it off easily. I could use one on my tractors also. Any size reccomendation?
Gene Davis (GA)
04-18-2005 18:05:50
 Re: Pressure washer in reply to Jim-IL, 04-18-2005 15:32:36
Be sure when you begin to clean the siding that you wet down the entire side of the house where you are going to clean with clear water first and then begin applying the soap from the BOTTOM to the top, NOT from the top down. This prevents streaking and spotting of the siding. Be sure you close and lock all windos in the down position and be sure all doors are closed firmly. The pressure washer does a good job of cleaning vinyl siding. Be sure to start with the pressure regulator adjusted low and raise to only what it takes to get the job done. I used about 750-1000 psi on mine and kept the nozzle putting out a fan-shaped spray holding it about 12-14 inches away from siding to prevent cutting the siding. Volume of water sprayed plays an important role in this job. You also need something like a fungicide or mildew remover in the soap to help clean and prevent the reoccurence of the mold/mildew. BE SURE TO WEAR GOGGLES AND EYE PROTECTION AT ALL TIMES.
old
04-18-2005 15:51:26
They work well to clean sideing as long as you spray the right way so as not to get under the sideing and blow it off. 1300-2500 psi will work well
