Tool Talk Discussion Forum
Weed wacker on wheels
Gary Schafer
04-17-2005 20:10:00
There are some weed wackers on large wheels with a lawn mower size engine on them. I tried one that I borrowed from my Brother in law. Seemed to work rather well especially in heavy grass, light brush. I can't remember the manufacturer. Thinking of buying one. Are there different manufacturers of these things? Don't see them many places.
Any comments on usefulness, longevity, what type to buy etc.
Thanks
Gary
Dave_Id
04-18-2005 12:36:11
 Re: Weed wacker on wheels in reply to Gary Schafer, 04-17-2005 20:10:00
I had a DR Trimmer, I bought it many years ago, when they were still cheap. I bought an optional chain saw blade for sapplings, but you have to have at least three or four workers pulling the trees away... What a slick machine
Nolan
04-18-2005 10:39:08
Aunt has a DR from several years ago on her farm. She likes it and says so. She's rather harsh, so that's high praise actually.
Midwest redneck
04-18-2005 08:23:23
Mine is a troy bilt, total junk, hard to start Techuseh engine and it cloggs up with grass and stuff. I want to buy a pull behind grass cutter for $1000 from Northern tool.
Sam#3
04-18-2005 06:13:32
I have a DR going into it's third season of tough work mowing fence rows. Works slicker than nose drippings with the offset I can keep the fence trimmed without getting in the hayfield and with steelcore it will trim most sagebrush. Heavy frame and running gear.
Bill(Wis)
04-18-2005 05:38:33
I bought a DR commercial model. A total mistake in my opinion. Too much money, poor quality, etc. After shelling out about 700 bucks for the thing, I saw practically the same thing at Fleet Farm for $250. Kawasaki engine on it gives a lot of problems although the Kawasaki engine on my lawn mower works beautifully. Offset axle is impossible to keep adjusted where you want it, especially if you want it to go straight ahead. What I'm saying is shop around and don't waste your money on a DR.
Fawteen
04-18-2005 14:58:54
 Re: Weed wacker on wheels in reply to Bill(Wis), 04-18-2005 05:38:33
Similar to my experience. Maintained one for a neighbor. Grossly overpriced, cheaply made POS IMHO.
When it worked, it worked great, but it rarely worked for more than a half hour. I liked the concept well enough that I bought a Sears Crapsman for something less than half as much. It had a similar problem with throwing the drive belt because the (*%ing OSHA safety stop was a P-poor design, but seeing as it was mine, I just took it the heck off and put a shorter belt on. Works like a champ now.
Dale in WV
04-18-2005 03:23:10
I bought a DR -- well-balanced, large rear wheels, easy to control, uses really heavy string trimmer string and it cuts through anything that gets it its way. I used it to trim down some poison ivy and other weeds and vines encroaching on my yard area. My initial problem was the cutting height adjustment. I hadn't shifted enough spacers to the right side of the string and I was blazing a trail clearing even the leaves, down to the dirt. And the plastic safety shield is there for your protection. If you attempt the trimming in rough terrain like I did, I'm glad I was wearing goggles, gloves and long clothing. Whatever gets in its way gets zapped and pieces go everywhere. Short of a goat, its the ideal machine for that area. I'd tried the typical string trimmer. The vines got the best of it. Not anymore.
Farmered
04-20-2005 04:31:01
 Re: Weed wacker on wheels in reply to Dale in WV, 04-18-2005 03:23:10
Dale. You covered everything except the window problem. I now cover my windows if I am using the Dr. within 50 feet. I use cheap grade 1/2 inch plywood which I fasten on with turnbuttons. My wife said "one more window broken and I go and the mower with me" I did a sliding glass patio door and the side window on my truck. The truck I park down the street now. Ed
Farmered
04-20-2005 04:30:18
Slowpoke
04-18-2005 01:31:05
I was looking for a gas tank for an old Green Machine string trimmer, and found this site which is selling a wheeled string trimmer for $250 with a 6.5 hp engine. I don't know if it's a good deal or not. In Kentucky, K and T Saw Shop. Click on the clearance specials for the trimmer. They carry parts for dozens of different brands of small power equipment.
www.ktoutdoor.com.
rockyhawaii
04-17-2005 23:17:24
I've used the Craftsman wheeled whacker for over eight years. No trouble with it except had to replace the starter rope. It does a great job, so last year I bought one for my son and he likes it too,
old
04-17-2005 21:03:02
D.R was the first to come out with them. Only trouble is the new junk engines on them, I have one and every year I have to replace the carb float bowl becauce its made of plastic
