Tool Talk Discussion Forum
adjusting chainsaw carburator
joe barnes
04-17-2005 15:58:16
I have a Stihl 021 saw that is out of adjustment. I just had the carb. rebuilt by the dealer and still runs poorly. It seems like it is starving for gas. If you don't keep "gooseing it" in between cuts it stalls, but then acts like it is flooded when you try to restart it. How can I adjust the carb., I don't have a tach. Thanks!
Don L C
04-18-2005 08:41:37
 Re: adjusting chainsaw carburator in reply to joe barnes, 04-17-2005 15:58:16
You paid to have it right....take it bask...
To adjust the carb -- start it, let it get warm.....at idle ajust low speed screw until it runs the fastest and the smoothest.....
Now hold it at full speed....adjust high speed screw until it runs the fastest the smoothest.....you got it ..... .
If you get it all messed up....very carefully turn the screws in (DO NOT TIGHTEN) then out 1 turn....
davefr
04-18-2005 13:34:15
 Re: adjusting chainsaw carburator in reply to Don L C, 04-18-2005 08:41:37
You never adjust the high speed jet of a chain saw for fastest speed!!! This will create an overly lean condition and the saw will eventually overheat and then seize up.
You adjust the high speed jet for smooth high speed and then richen it up until it starts to blubber or create a 4 cycle sound.
Go here to this link. It's the best chain saw adjustment guide you'll ever find. Download the .wav files to you know what to listen for.Link
n
VaTom
04-18-2005 17:46:54
 Re: adjusting chainsaw carburator in reply to davefr, 04-18-2005 13:34:15
Dave, I think Don was used to the old Homelites and such, where that was the best way to adjust them. Fried a Husky that way. Guy who was working here thought it was just like all the other saws he was used to. Oops.
Dave Sherburne,NY
04-17-2005 18:58:38
Starving for Gas ????? Check that filter in the fuel tank . Take a piece of wire bend a hook on the end and fish it out of there
stihltech
04-17-2005 17:20:46
Depending on how many adjustment screws you have, turn the smaller screw(s) in all the way gently. Then turn them out 1 turn each. This should get you started. If the idle seems low, turn the large screw in one turn.
Now, for my best advice, TAKE IT BACK. What kind of dealer will leave you with this problem? None that are any good.
