Tool Talk Discussion Forum
mac chainsaw
huby
04-16-2005 19:57:19
i am tired of having my butt whooped by this saw. Someone out there has got to be able set me straight. Mac saw runs at idle even high idle. Blows gas everywhere when you try to go full throttle (out of carb and muffler). rebuilt carb same problem, cleaned muffler same problem, pulled off flywheel and checked key way (looked a little worn but did not look to have sheared)same problem. Kicks like heck when you try and crank it must have plenty of compression. Almost seems to be out of time somehow.
jeffcat
04-16-2005 23:26:58
 Re: mac chainsaw in reply to huby, 04-16-2005 19:57:19
Also-- what model is she? Reed valves on Macs go back to the 60s. jeffcat
Roy Suomi
04-16-2005 21:43:55
Change the reed valves just in from the carburetor. If they're not sealing, compression will leak back thru them....
