Tool Talk Discussion Forum
Stihl not oiling
tntractor
04-15-2005 23:09:41
A friend brought over a Stihl MS 290 chain saw that is not oiling the chain. Any ideas? Any hlep ouwld be appreciated.
TIA, Bud
John *.?-!.* cub owner
04-16-2005 19:28:54
 Re: Stihl not oiling in reply to tntractor, 04-15-2005 23:09:41
Will it oil if you pump the manual oiler. If not it is probably plugged form not being clena enough when adding oil. If that"s the problem, may have to replace the pump.
Van in AR
04-16-2005 21:23:15
 Re: Stihl not oiling in reply to John *.?-!.* cub owner, 04-16-2005 19:28:54
No manual oiler on Stihl saws
Van
Turtle
04-16-2005 08:20:56
After checking the obvious as said before you might check that the sprocket is on right. There is a groove that must ride on a pin. This is what turns the pump. I discovered this after the Stihl mech helped me out. Just a possibility.
Michael_E_Tx
04-16-2005 05:45:35
Start simple. Take off chain and bar. Clean bar groove. Clean oil hole in bar. Start chainsaw, making sure there is oil in tank and see if any oil is coming out oil passageway. Check oil tank for accumulated crud. Good luck.
Michael
riverbend
04-16-2005 05:25:11
When my saw quit pumping oil, there was a plastic gear behind the clutch that stripped.
stihltech
04-17-2005 17:32:30
 Re: Stihl not oiling in reply to riverbend, 04-16-2005 05:25:11
Start with the bar off like previous post.If no oil,clean out oil tank really well and try again. If nothing, pull the sprocket (one clip) and clutch. Clutch is a reverse thread, hold the crank by using rope through the sparkplug hole. You will now see the worm. Look at the gear, should see all inclines in good shape. Drive wire on top should not spin on gear. If it does, replace.
Pull the pump. 2 screws and an output nozzle. Gear should spin freely inside. Look at pump inlet, must be clear. If it is not, clean it and spray brake clean through the hose untill clear. Reassemble and should work. If not, you need a new pump.
