Tool Talk Discussion Forum
Wisconson VH4D1 timing
Lance Takara
04-15-2005 11:25:58
Does anyone know how to set the timing for this engine. There is a timing mark on the magneto but couldn't find a corresponding mark on the drive wheel.
Thanks in advance for any assistance.
Lance
Jon H
04-15-2005 15:46:52
 Re: Wisconson VH4D1 timing in reply to Lance Takara, 04-15-2005 11:25:58
You need to remove the flywheel screen to get to the timing marks. The static mark is a line scribed at the top of the air intake opening on the shroud. the flywheel has an X cast into one of the flywheel fins,about in the center of the curved part of the fin. The letters DC are cast at the base if this fin.
With #1 cyl on compression,line up the leading edge of the fin with the X mark,with the scribed line at the top of the shroud.
Install a plug wire in the #1 hole in the mag cap. Hold the plug wire 1/8 inch from the metal mag case,then turn the mag gear clockwise tripping the impulse untill the wire sparks. Hold the mag gear in this position and install mag to engine. With the mag installed,the mag gear tooth with the X mark is visible in the lower half of the inspection hole.
When the mag is correctly timed,the impulse will snap when the timing marks on shroud and fin are lined up.
Jon H
04-15-2005 15:44:29
Install a plug wire in the #1 hole in the mag cap. Hold the plug wire 1/8 inch from the metal mag case,then turn the mag gear clockwise tripping the impulse untill the wire sparks. Hold the mag gear in this position and install mag to engine. With the mag installed,the mag gear with the X mark is visible in the lower half of the inspection hole.
