Tool Talk Discussion Forum
Suburban Barn/ Garage
rdmace56
04-14-2005 18:00:35
I have a large country suburb lot with plenty of room for a small garage/ barn. All I want is to get a roof over my old toys. My tools can stay in the garage on the house for now.
No tall row crop tractors in the plans so 10' celing is OK.
I am kinda partial to the old wood barn siding look versus steel. Heck I would even go with a sliding door. Anyone have opinion or pole construction with shingle roof and plywood siding. Prices seems about the same as premium steel. Yea I know you have to paint it. I just don't know if I would like steel after it gets a few dents and my wife changes her mind on the color choices.
Chuck(VA)
04-16-2005 20:21:35
 Re: Suburban Barn/ Garage in reply to rdmace56, 04-14-2005 18:00:35
The T-111 siding has been on my barn for 21 years now and I have not had any delamination and only re-stained it once. I used Oil-based Stain(opaque)instead of paint. And sealed the bottom two feet front, back and with the same stain before installing them. Once it was installed I stained the whole barn.
Just a suggestion.
OldFarmTractor
04-15-2005 07:08:28
There are numerous books out there on pole barns.
Boog
04-15-2005 06:25:50
Steel roof will last longer than shingles.
Steel siding will last longer than T1-11.
Steel will not last longer than old fashion pine board siding.
Block or concrete foundation is what really makes the old barns outlast pole barns. (treated wood still has a limited life in the ground)
Whatever you do, put in good roof vent system; this will prolong life of the building by allowing moisture & heat to escape.
BillNYS
04-15-2005 05:42:14
I also like to look of a wood sided pole barn. I built mine a couple of years ago. After hearing a few stories about the quality of today"s T1-11, I decided to do it the old fashioned way. I used 1x12 rough cut pine boards with 1x3 battens. It is starting to weather nicely. There are 150 year old barns arould here with this same siding, still in decent shape, so I expect it to outlast me and my kids.
Midwest redneck
04-15-2005 02:40:09
I built a 50 X 22 X 8' garage in 2000. I wish I would have put up 2 courses of block for the walls to sit on so that I could have a 10' ceiling, oh well to late now. But my garage is T1-11 siding and 5/12 roof, cement slab with 42" footings. About $20,000 to build.
MarkB_MI
04-14-2005 20:05:38
For my 30x40x10 post frame shop, I went with T1-11 siding, shingle roof and roughsawn cedar trim. I wanted it to match the house, which has shiplap cedar siding. I've been pretty happy with it. I'm sure I spent more time building it than I would have with steel, but it came out real nice. You'd never guess it is a pole barn from the outside.
I went with an 8' overhead door rather than a slider. I sacrificed two feet of clearance, but it sure seals up tight.
My biggest concern is water damage to the T1-11 from rainwater splashing on the siding. I suppose I'll have to put gutters up.
rdmace56
04-14-2005 20:32:08
 Re: Suburban Barn/ Garage T1-11 in reply to MarkB_MI, 04-14-2005 20:05:38
I have a 20 year old yard barn with T1-11. It has just a hint of delamination near the ground and has been painted only three times. I want 10 foot walls too, what is best way to accomplish with 4x8 sheets? I was thinking maybe a joint at lower end so it could be replaced if damaged.
jhill
04-15-2005 19:57:20
 Re: Suburban Barn/ Garage T1-11 in reply to rdmace56, 04-14-2005 20:32:08
When I built my shop 14 yrs ago I was able to get T-111 in 10 ft sheets. I would think they would still be available. Mine has held up great.
I stained mine and have renewed it once.
MarkB_MI
04-15-2005 19:13:16
R.D.,
For 10 ft sidewalls, I used the 5/8" Z-molding that is specifically made for this purpose. I goes over the lower panel and under the upper panel so rainwater can't get through the joint. I put my short piece on top, but your idea of putting it on the bottom makes sense.
Mattlt
04-15-2005 05:59:34
I believe there's a Z-shaped piece of metal flashing that you can put in the joints. That should keep water from getting in behind the bottom sheet.
Good idea to have the "short sheet" at the bottom - that's the one that's going to need replacement someday.
rdmace56
04-15-2005 06:04:15
 Suburban Barn/ Garage - splash protection in reply to Mattlt, 04-15-2005 05:59:34
Yea, Menards even has some fake concrete looking stuff that might work for lower side. You can get brick, rock, etc. I saw a similar trick on a Morton display barn a while back.
