Tool Talk Discussion Forum
Growler
wm morath
04-14-2005 08:22:02
does anyone have a wiring diagram of a growler I bought one that somebody had been into and didnt wire correct.Thanks Bill
buickanddeere
04-14-2005 12:08:10
 Re: Growler in reply to wm morath, 04-14-2005 08:22:02
A diagram of myself holding a barley pop and having a good time will make a growler out of my wife.
Bob
04-14-2005 09:05:23
A growler is simply a coil of wire, probably connected through a switch, to a power cord.
It sounds like you may have a more complicated setup, though? Does it have a light built in for continuity checking? Units set up like that were great for shocking the &@%^ out of a person if the polarized plug was reversed! (I suppose the older units didn't even have that safety feature.) I believe some units were set up with a second winding wound along with the "growler" winding that produced a safer, lower voltage current for the continuity light.
I have even seen a unit with provisions to connect 6 VDC to a separate set of terminals, and use the unit as a magnet charger.
Knowing what unit you have, and even posting a picture would help.
wm morath
04-14-2005 14:02:09
 Re: Growler in reply to Bob, 04-14-2005 09:05:23
It is a type with a light bulb.no brand name.Bill
Bob
04-14-2005 15:33:44
 Re: Growler in reply to wm morath, 04-14-2005 14:02:09
How many terminals on the actual electomagnet... just the two for 120 Volt power, or are there others?
