On the commercial end of things, such as high rise apartment buildings, the windows typically specified are still aluminum. All of the parts are aluminum extrusions which are assembled by the manufacturer, for example like Wausau, and Moduline, both from Wausau, Wisconisin. The key to eliminating the thermal conductiveness is what is referred to as a "thermal break" in the extruded frame and sash extrusions, which means if you look at a given extrusion in section, you will find that in the middle of it, a material that does not conduct heat or cold is sandwiched in, it stops the thermal conductivity at that point, so the in-board side of the window does not sweat or frost up etc. Glazing can be a wet ( bed of silicone such as Dow 795) or a rubber gasket within the sash and a snap cover applied over the assembly with weeps to let moisture out of the glazing pocket, the glass is always a thermal pane with the dead air space in between. Glazing can be of many different kinds of glass with surface treatments, annealed, or tempered etc. On this end of things, I don't think aluminum will be changed, they pass some stringent air and water infiltration tests, some of which I've witnessed at testing labs. Structurally, they can be designed to take well over 54 pounds per square inch windloads, again this is in the mid to high rise building applications, but I would think there are aluminum manufacturers out there who cater to the residential end, you just have to know what you are looking at to make sure it is a decent product, also ask how or what the line has been tested for. I think all aluminum residential windows are subject to some sort of AAMA ( American Aluminum Manufacturers Association )testing, don't quote me on it though, LOL. Anything that is not thermally broken, ( like what has been mentioned here ) typical of low end performance windows offered in the 60's will most likely perform poorly due to design and subsequent poor installation. It is very important when installing any window, door, or a thermal and moisture barrier like flashing, that the installation is done properly, in accordance with a good design. Windows can be designed to high performance standards, be it wood vinyl clad or extruded aluminum, the installation must be done properly, and the rough opening must be of the correct size, which is many times not the case with masonry openings in brick or concrete block type walls. The window unit perimeter seal and jamb insulation is important as well.
