Tool Talk Discussion Forum
Stihl Chain saw question.
MMRTI
04-12-2005 07:06:05
Neighbor has a Stihl model 021 chain saw that has been used very little. I tried it out and it used very little bar oil compared to my older Johnsreds. Is the bar oiler adjustable on this sawn and if it is where is the adjustment. Thank you ahead of time.
Easy
04-12-2005 21:53:05
 Re: Stihl Chain saw question. in reply to MMRTI, 04-12-2005 07:06:05
My 024 wasn't oiling, so I wrapped a rag around an air nozzle, and stuck it in the fill hole - blew out whatever was blocking it. Easy.
Michael_E_Tx
04-12-2005 21:38:52
I"ve got one. Not adjustable. Oiler has always worked, but usually 1/2 to 2/3 tank of oil to tank of mix, depending on the bar oil.
Mike in Northern IL
04-12-2005 19:19:19
2 Things
The oil flows through a small hole in the bar just above the were the mounting stud goes through. Make sure it is clean as well as the chain groove. This is assuming it is a Stihl bar or a bar compatible for a Stihl saw. If it isn"t the saw will not oil the chain
Second, On some Stihl saws the oiler is adjustable. The adjustment is a screw on the bottom of the saw on the bar side. I can"t find my service CD to see if the 021 has an adjustment.
No reserved name
04-12-2005 14:55:47
I have a 029 and its the same way.I took it in to get fixed and the Service center told me thats the way they are.
