Tool Talk Discussion Forum
Pull behind yard spreader
Chuck Davis
04-10-2005 05:58:33
Well guys i am going to buy my 3rd spreader in 9 years. Agri-fab,craftsman both junk.These spreaders were used twice a year and the cheap stamped cog wore/corroded out of them both. yes they were washed out completely after each use,i know this as i am the only one that does the fertilizing.I aint afraid to spend good money on a good product.Anybody out there own a Quality spreader that you can suggest?
Thanks, Chuck Davis N/W Indiana.
Bob - MI
04-11-2005 05:30:00
 Re: Pull behind yard spreader in reply to Chuck Davis, 04-10-2005 05:58:33
I have one from Earth Way that I bought almost 20 years ago now and have never had a lick of trouble with it. They are a little expensive but like many things, you get what you pay for. They have a complete line and have homeowner and professionalk models. I see them at farm stores and some feed mills. I have looked at them on the web so I know that have a website. I have helped them sell a few over the years by loaning mine out. Everybody loves it and luckily I have managed to have it returned.
Leland
04-11-2005 04:43:37
Argi fab and sears are built in the same building in Sullivan IL ,I used to slave away there but usually they hold up really well I always smear my gears with grease to prevent rust after each use and wash very well.
Farmall Teen
04-10-2005 17:10:17
We have one with plastic wheels and they stink. When you buy a new spreader, get one with real rubber wheels
MAC,IL
04-10-2005 08:04:04
I had a couple and still have them, here is what I did. The gear box was half a** anyhow, so I took it apart. Greased. Resealed mating surfaces and used bolts to keep the sides together tightly. I got these from the local farm supply place. I always prefered a drop spreader, seems they are hard to find unless you buy those push/walk type and I got to much ground to do that.
Don L C
04-10-2005 20:40:21
 Re: Pull behind yard spreader in reply to MAC,IL, 04-10-2005 08:04:04
If you have a large area to cover Northern has a 12v salt spreader that fits into a 2" reciever...
I mounted a 2" recever on the front of my 1620 Power King lawn tractor...put a switch on the dash so I can turn it off/on.....it has about a 80# hopper on it...be sure to sift the fert.through a 1/4" hard ware cloth....don't fill hopper at first.this spreader is adjustable and comes with a setting chart.....Caution --- do your test settings out of the front yard....
