Concrete floor repair
Big Jim
01-04-2001 12:56:27
I have a gap (1/2" approx.) in one spot under my garage door. I poured the floor myself and its not level in that spot. My skills as a concrete mason are lacking. Is there any good product I could use to level and fill in this spot? It would have to be real strong as I frequently use the garage to repair heavy equipment such as farm tractors. Any advice appreciated.
Tools
01-11-2001 09:32:07
 Re: Concrete floor repair in reply to Big Jim, 01-04-2001 12:56:27
1. The "milk" is probably latex admix. Use instead of water to make mortar anything STICK.
2. The trick to STRONG concrete is mix it as DRY as feasible and cure it as slowly as feasible. I'd use a paintbrush and wet the area with the latex, then JAM in concrete (something like 5 parts sand, one part portland mixed with just enough latex or water so that you can make a ball out of a handful when you squeeze it, ought to work fine). Then mist the area with water and cover it with plastic for a month or so. Check every week or so to make sure it isn't dried out, add more water. After a day it'll be strong enough to walk on and stuff, but try to keep it from drying out too fast (that's the point for wetting the area first, so when you put your concrete in the existing concrete won't wick away all your moisture before the concrete can cure).
Good luck
Mike
Shep
01-04-2001 21:32:41
Big Jim -
For repairs in my new shop floor (1" redheads were not properly spaced) I used "Hydraulic Cement". Available at most home centers. This is pretty easy stuff to use, mix 3 parts powder to 1 part water to consistency of toothpaste/oatmeal, pour in and finish. Sets up in about 3-5 min or use slow stuff that sets in approx. 15 min.
I've had good luck with it so far. I have used this for patching holes as it is waterproof, lining lower course of cinderblock to repel outside water, fixing cracks around drain and also as bonding element when redheads reinstalled in new holes.
Good Luck,
Shep
T_Bone
01-04-2001 20:18:57
Hi Jim, They make a concrete adhesive called "milk" as it looked just like cows milk. You clean the crete good then apply the milk, mix sand & portland and finish off. No cracks or won't chip other than chipping like normal concrete, another words it won't flake off. Brand wise I can't remember and I would guess any building center would carry it. It's been to many years since I used any so can't tell you more.
T_Bone
Jim in N M
01-04-2001 19:49:07
Scribe the bottom panel of the door and cut along that line with a saber saw ans re-install the weather strip my solution----Jim in N M
chief613
01-04-2001 17:07:02
if its just a gap under the door, try gettin an oversized weather stip for the door
r hudson
01-04-2001 16:06:23
Big Jim, do you mean that your floor has cracked, and sank down 3/4" or cracked and seperated 3/4"? i don't think you'll ever get a pour of concrete less that 4" thick to hold up to heavy loads. if you've got two different elevations of 3/4 inch, i beleive its going to be break up the smallest part and repour or coat the lower level with some resilient material, epoxy/pea gravel for example.
email me if you like.
Fred OH
01-04-2001 15:39:42
Cut out about a three inch slot across there and put a piece of 1 1/4" pipe in the slot protruding up about 3/4" and pour new mix around it. Don't forget to plumb it with a level. L8R----Fred OH
bob
01-12-2001 04:44:52
 Re: Re: Concrete floor repair in reply to Fred OH, 01-04-2001 15:39:42
we used a vinal concreat from Menards in our basement it was easy to float out to take care of low spots Don,t know if would hold or with big equipment and outside elements held up good there Years ago i overlaid a patio floor about 1-2 inch made paste of cement and painted on then applied concreat fairly dry couldn,t use enough gravel to gey any strenght
