Tool Talk Discussion Forum
Metal bandsaw ID
Wally Verbeck
04-09-2005 17:26:50
Was given a metal cuttin bandsaw a couple of days ago. It is an "Industerial Metal Bandsaw", and has the folling info on the tag:
Southern Tool & Equipment of T.R., Inc. P.O. Box 1106 Travelers Rest, S.C. 29690
Serial # 014876
The blade is 3/4" x 114"(approx)X 1/16", with about 10-12 TPI.
The frame (Legs) and pan are of folded and welded 1/8" plate steel. The pan is sealed, but there is not a wet kit on it now. The deck (?) is 3/16" plate steel, & the vise jaws look to be "cast" steel, and they will open to over 14". The jaws have a drop ratchet for quick adjustment. The saw head (?) is constructed with the main beam of 2 1/2" x 3 1/2" x 1/4" thickness. The backing plate is 3/16" I believe. The wheels are of steel, with a turned face for the blade to run against, behind a lip. They are about 12". Except were strength is needed, most of it is made out of 1/8" plate. It has an air cylender, with a bleader valve to controll the rate of decent. It has a 90* gear box to drive the drive wheel, with a three step pully, so I guess it was a "three speed" saw. Was told it ran when they got it, but the blade had a couple of kinks in it, so instead of gitting a new blade, they just shoved it in a corner and forgot about for about the last 20 years. In fact, the motor ran so well, it got up and ran off. If anyone has any info about a saw of this type, please help. Need to know everything about the motor, how to align the saw if you can help. Thank you. If I knew how to post a pic, I would include it.
Wally Verbeck
Cleveland, Tx.
j-tex
04-11-2005 09:47:26
 Re: Metal bandsaw ID in reply to Wally Verbeck, 04-09-2005 17:26:50
search the archives on this tool board, there are several discussions about this saw. sounds just like mine model HD10, great saw got mine also without a motor. It takes a 1hp 1725 rpm i had the phone # but now i cant find it. I just went to the local motor shop and bought a rebuilt motor for 50 bucks. I only paid 10.00 for the saw so I dont havea lot in it. looked brand new when i got it.
big jt
04-10-2005 23:37:31
Wally
I just bought a saw which is pretty much the same thing. No manuals or tags on mine. Let me know what you find out.
Good luck and congrats on the good find. Mine cost $875 and I had to put together a switch.
jt
Wally Verbeck
04-10-2005 18:36:11
Ok, here goes.
Will try to post a link to three photos.
Link
Go to bottom of page and find my name and click on it and they will come up.
Wally Verbeck
Cleveland, Tx.
69* Rain
Mike Burdick
04-10-2005 08:35:43
Wally,
Post a picture please, I'd like to see it. To do so, when posting or reply, look down at the bottom and under "Optional Image URL" post a link to the picture.
You will need someone to host your picture - your Internet Provider will usually have free space for you or you can use some of the free picture host sites on the 'net. Do a Google search.
Here is an example of one such site that you can sign up:
Slowpoke
04-10-2005 00:14:09
What luck! You have a saw worth $500 at least, without the motor. Go to www.southern-tool.com and see if they have the parts list and set up instructions. The motor size should be listed. Maybe 1-1/2 hp?
I replaced the 1 hp motor on my $150 Harbor Freight saw with an old 1/3 hp. I relied on the auto shut off, which works when the cut is finished, but the blade jammed when I was busy elsewhere. There is no thermal protection on the original motor, so it got nice and hot and took out the starting windings. The 1/3 hp motor drives the blade with no problem.
