Tool Talk Discussion Forum
OT-STRANDED F150 HELP
Mark B in Mi.
04-08-2005 13:43:28
I just got to work 4pm. it took me 2 hrs to get here (normally 45 minute ride), but im glad i made it. It ran good for the first half hour then when the truck heats up i lose power, feels like the gas is shut off. i can pump the gas pedal and make it go to about 25 mph. then pull over go again then die out again. no passing gear power and it never stalls out completly but surges at idle. no problem starting up, even when hot. please help, its gonna be a long ride home at 11pm tonight.
Don L C
04-10-2005 20:49:52
 Re: OT-STRANDED F150 HELP in reply to Mark B in Mi., 04-08-2005 13:43:28
I had a puuged exhaust converter do that on a rented ford car....
shannon from ohio
04-09-2005 18:38:15
replace gas filter
Binder-Man
04-09-2005 06:55:06
Go to www.fordtrucks.com great web site, anything you need to know about ford trucks and information on them is there..... ..Binder-Man
L Mills
04-09-2005 01:28:00
Had a 1984 F150 V8 - did the same thing - replaced mechanical fuel pump and fuel filter at the carb and it ran fine after that. It had
175,000 miles on it at the time.
Mark in MN
04-08-2005 19:39:47
 ford in reply to Mark B in Mi., 04-08-2005 13:43:28
Does it make any difference whether the tank is full or near empty? Has this come on suddenly or gotten worse over time? How many miles on the truck? Trying to help...
Mark
MAC,IL
04-08-2005 18:26:38
Mark: I have not driven a ford for many years. But does it have a mech pump? Arm type or plunger type?
Reason asking is I had a chevy in like 84, had basically the same problem when hot. Finally found the fuel pump. Had a plunger type pump that ran off the cam. The return spring had broken and there fore it did not get a full stroke on the return. Only acted up when engine got hot. Might check if applicable.
Weirsdale George
04-08-2005 16:58:53
About all possibilities have been covered. If everything else fails, look for either a crushed metal fuel line, clogged fuel intake screen in fuel tank or a clogged fuel line.
Just thought of one more thing -- Look for a leaking vacuum line.
thedink
04-08-2005 16:20:01
ALSO YOU SHOULD CHECK THE EXAUST SYSTEM FOR BLOCKAGE
mj
04-09-2005 17:53:01
 Re: OT-STRANDED F150 HELP in reply to thedink , 04-08-2005 16:20:01
DITTO on checking for a plugged cat.
DH in Carolina
04-08-2005 14:38:00
Had the same problem on a 300 6 a few years ago. Found inline fuel filter clogged and the short fuel line hose on the filter collasped. Can't remember if fuel filter screwed in the carb or if connected by two short sections of hose. No problem to replace as it is on top of engine next to carb. Danny Hearl
Gerald J.
04-08-2005 14:09:02
Water in the fuel may have plugged the fuel filter.
Fuel pump may be going out.
Fuel pressure regulator may be going bad. I had one leak gobs of fuel to the vacuum lines that filled the cylinders and crankcase with gasoline. That was hard on that engine. It was fuel injected.
If not fuel injected, it may be that the tank vent is plugged. Pull the gas cap to see if it runs better.
Gerald J.
lucasss
04-08-2005 13:58:26
was going to try to help.. you may want to post the year and the engine you have. lucas
RustyFarmall
04-08-2005 14:08:40
 Re: OT-STRANDED F150 HELP in reply to lucasss, 04-08-2005 13:58:26
If it's an older truck,(before fuel injection), the most likely culprit is the in-line fuel filter, right on the carburetor. If the truck is newer than that, I'm lost.
Mark B in Mi.
04-08-2005 14:21:52
 1986 F150 STRAIGHT 6, AUTOMATIC in reply to RustyFarmall, 04-08-2005 14:08:40
IM SORRY, ITS A 1986 F150 6 CYL. CARB-NOT FUEL INJ. THANKS
Rajah from Delhi
04-08-2005 16:26:19
 Re: 1986 F150 STRAIGHT 6, AUTOMATIC in reply to Mark B in Mi., 04-08-2005 14:21:52
My cousin Vindar did had a fuel filter clog up on his taxi.
Rajah
scot_c
04-08-2005 15:26:35
cheap first- try pulling the thermostat if it stays cold maybe it will run. 4cyl. dakota I had wouldn't run in traffic till i pulled thermostat
Mark B in MI
04-08-2005 17:03:29
 Thanks ALL! in reply to scot_c, 04-08-2005 15:26:35
Thanks for all the replys. I punched a hole through the Fuel Filter connected to the Carb (it also still has an inline filter) Im gonna try to make it home. If all else fails I just take a nap when the going gets bad and let it cool down then continue on home. Thanks again for all the advice!
toolman
04-08-2005 19:09:00
 Re: Thanks ALL! in reply to Mark B in MI, 04-08-2005 17:03:29
try throwing some methel hydrate in your tank ,let it set a couple of hours until you head home, if any water in your gas it should help by then,then like all the others have said, look for the simpler things and work your way up.
lucasss
04-09-2005 04:23:20
 Re: Thanks ALL! in reply to toolman, 04-08-2005 19:09:00
ive seen alot of those fords quit when they warm up or higher rpm and the ignition module pack mounted on the fender was bad.let it sit and it starts right up.then, quits. lucas
toolman
04-09-2005 12:09:42
 Re: Thanks ALL! in reply to lucasss, 04-09-2005 04:23:20
you know you could be right, i try and stay away from fords as much as possible(but did just buy the wife a explorer) but i had i think it was a 79 f250 years ago that did that and it was that module, a black box about 4x4 i think, same type of acting up , this one would buck like someone was pulling it with the clutch out also, hard to say without looking at them and finding your way along though.
