A local Wood Doctor dealer put me in touch with the owner of an Energy Converter. Interesting review he gave me. First he complained about having to clean creosote off the fan quite regularly, else it vibrated. He admitted that it produces lots of heat and uses proportionately less wood than his neighbour's Wood Doctor. He heats 1500 sq ft and a 40 X 40 shop in which he works on his combine, so it's a big building. Apart from the creosote the device apparently works well. The fan on the chimney draws air down through a hopper. The wood sits up high at first, then gradually falls down into the main firebox after it is thoroughly dry. There is very little smoke, apparently, and he said that he could hold his hand over the chimney and feel little heat when it is running full blast. This fellow loaded the system with prestone -- three drums of it at $1000 per drum. Ulp. He further commented that the fire burns best if all of the blocks in it are the same size, ideally 6" in diameter or so. He admitted to burning junk wood, especially poplar, but doesn't link this to the creosote problem. Seems the creosote happens when cold air meets the chimney. I had that happen with an airtight stove back in the '70's, I couldn't keep the flue hot enough to prevent creosote buildup on cold, windy nights. Oh yeah, the Mennonites build these furnaces, and they deliver when they have them finished, not when you want them. They waited over a year for the unit. Another guy who looked at his bought one and it had a leak. My advisor blamed the installer for not pressure-testing the unit before firing it up. And that's all I have learned so far. If anybody knows anything more about these units, I'd like the hear.
