Tool Talk Discussion Forum
Buying a cheap hydraulic press
John in MA
04-07-2005 22:04:03
Long time no post. Anyway, I'm going to be buying a cheap hydraulic press. Size and budget restraints limit me to the common ($130-165) import 12-ton style, but I'm wonder which one is best.
The main types out there are H-frame with the jack under the top bar, H-frame with the jack over the top bar, and A-frame. I'm thinking I might get an A-frame since it seems stronger, but I'm unsure.
Opinions?
Farmered
04-09-2005 23:27:40
 Re: Buying a cheap hydraulic press in reply to John in MA, 04-07-2005 22:04:03
12 ton may be OK for a bearing press or for rebuilding water pumps but if you have cultivator shanks or tractor axels to straighten then 20 tons may not be enough. I had a 50 ton at my last employment, Always got the job done but sometimes not much to spare. Ed
KEG
04-08-2005 19:19:00
Here's another source: Cook's Saw Mfg. Inc. (www.cookssaw.com) 800.473.4804
Just got their catalog and their selling a 20 ton shop press (Reg. $189.95) for $89.76. Heck for that price you could pull off the jack and sell the steel for scrap and still be even. Doubt it has any extra steel and could bend/distort. Only problem is shipping cost. Waiting to call them on Monday to find out how much, cause these things are heavy.
KEG
John in MA
04-08-2005 21:24:43
 Re: Buying a cheap hydraulic press in reply to KEG, 04-08-2005 19:19:00
Thanks, sounds like a deal. I"ll give them a call. Is there an item number or something I"d need to ask for?
Charles (in GA)
04-08-2005 18:38:15
12 ton isn't much, You probably should look to buy a 20 ro 25 ton press, even that may not do everything you might want to.
I always wanted a press, don't like the cheap ones with the bottle jack. Finally bought a clean used Dake 25 ton from someone on Ebay. Total cost including my expenses to go get it was around $500. I think I snagged a bargain. The same press new is $2750. I bought several different bearing splitters to use with it, and haven't used it much but it is handy to have.
Charles
Gerald J.
04-08-2005 14:10:33
None of the cheap presses have any excess steel. They are likely to bend a little at the full load the jack can produce.
Gerald J.
Bigdog
04-08-2005 13:42:39
Harbor Freight still has their 20 ton H frame press on sale for $169.
John in MA
04-08-2005 14:52:10
 Re: Buying a cheap hydraulic press in reply to Bigdog, 04-08-2005 13:42:39
What's the catalog SKU number? Online they're still shown at $199.
Thanks
