Remote controls
rhudson
01-04-2001 07:42:30
One of the most usefull tools i use in the winter is a remote control system for electrical devices. this system lets me turn on and off just about any electrical device from or near my house. (engine block heaters, lights in my shop 200ft away, dust collectors from any station in my wood shop, etc) its sold under many brands but i have found the cheapest source at x10.com. my basic kit cost about $50, but i've added motion detectors, alarm system, and video recording security. With this system you can have 16 items on one electrical line but be able to control each one individually. really simplifies wiring. No i don't own stock in the company
JerryB
01-08-2001 19:50:27
 Re: remote controls in reply to rhudson, 01-04-2001 07:42:30
I've used the X-10 system for about 10 years. It is great, with little trouble.
rhudson didn't mention it, but the system can be equipped with a variety of individual timer devices with multiple on/off cycles. Also has a computer interface available that allows you to program a control unit with complex on/off/dim commands that can contain specific day functions (like weekend skips). This control module then runs the desired program without being on the computer! When you want to change or add functions, just fire up the computer.
Probably the most important thing about the X-10 system is you can buy one piece at a time and just keep adding. I've got about 1/2 of the lights and heaters in my house, and hanger/shop on X-10 now.
JerryB
franz
01-04-2001 23:41:21
Check out the neat little remote Home Depo has for turning on Christmas lights from the car. Works like a garage door opener.
VaTom
01-04-2001 20:03:33
Geat system. Ebay usually has a large selection. Use "x-10" for the search. My primary interest was to transmit a signal from a driveway sensor 1000' away to the house without radio. One summer of electrical storms and still no false alarms! It also was the easiest way to send an alarm signal to the house. Pair of diodes and I only needed one sender. This after two consequetive nights' attempts to break into my shop. Sleeping just fine now.
Bill D
01-04-2001 13:55:20
Tell me some more about this Sounds like the perfect device to turn on the shop furnace in the morning
rhudson
01-04-2001 15:46:22
 Re: Re: remote controls in reply to Bill D, 01-04-2001 13:55:20
i'll try to explain the simplest system. a. A radio transmitter, battery powered, several models from keychain fob size to alittle larger than a deck of cards.
b. A receiver module that plugs into any ac outlet. (it receives radio signals from item "a" above, and puts an encoded signal onto any ac line fed from your breaker box) "a" and "b" must be within 100 ft. of each other. you may place several receivers around house, shop, shed anywhere you have ac power. as long as you are within about 100 ft of a receiver the system will work.
C. Appliance module, this plugs into any ac source and inturn a light, appliance, etc is pluged into it. Different types for different applications, 120v, 220v, dimmer, motor applications.
Each appliance module has a code number 1 through 16, you set it to what ever you want. several can have the same number if you like. Now when button #1 is pressed on item "a", it sends a radio signal to item "b". Item "b" inturn puts a signal on your house electrical wires to turn on any and every item "c" that has been set to code #1.
They have too many types of modules and controlers to talk about here, it can be pretty complicated if you look at every thing at once. I went to the web site and ordered a basic kit to start with. Added to it as i found ways to use it, and you will find ways to use it. if you want to look at actual ones, Radio Shack has the basic modules at about twice the cost of x10.com.
i have a shed in my back yard. i can turn on each of 5 500 watt flood lights, 5 sets of lights in seperate bays, block heaters for each of three tractors with out leaving my house or truck or from a remote in my jacket pocket. There is only one 220 volt cable feeding the shed.
sorry to run on here, but i guess i am a control freek and for under 100 bucks you get a lot of control.
Alvin
01-04-2001 17:07:34
 Re: Re: Re: remote controls in reply to rhudson, 01-04-2001 15:46:22
Golly-- that would just about drive the Honey bananas, with turning things on and off from anywhere and not being able to keep tract of what is happening. It is bad enough now with our own tv remotes.
Richard
01-05-2001 03:37:09
 Re: Re: Re: Re: remote controls in reply to Alvin, 01-04-2001 17:07:34
Very handy devices indeed!
Just keep in mind, it has run off the same mains. In otherwords, for those of you that have a shop with it's own transformer and pole, it probably won't work from the house. There is another company out there making powerline modems that will transmit and recieve any distance through the powerlines, including transformers and boosters. Not sure what the price is but it is what our local electric company is doing to read the meters now (30 miles out of town).
