Tool Talk Discussion Forum
loader problem/question
dieselade
04-07-2005 04:54:54
I put a set of forks on my loader and the loader won`t lift what is on the forks, but will lift the same weight in the bucket. Is this the physics of leverage or what?
paul
04-07-2005 06:24:00
 Re: loader problem/question in reply to dieselade, 04-07-2005 04:54:54
Yup.
You extend the load a couple feet farther out, and you can lift a lot less. Lever & fulcrum.
--->Paul
tim brune
04-07-2005 16:09:32
 Re: loader problem/question in reply to paul, 04-07-2005 06:24:00
it would seem to me that you would have a problem much sooner with counter balance than with limited power. is it a low hp loader ?, or do have a lot of counterweight ?
just thinking out loud..... .....not a criticism.
dieselade
04-08-2005 04:20:12
 Re: loader problem/question in reply to tim brune, 04-07-2005 16:09:32
this is a heavy caseih 585 with a heavy duty loader. i guess around 50hp, not sure....but it is the heaviest tractor per hp. somewhere near 6000lbs. my rear end was not comming off the ground.
paul
04-08-2005 11:37:09
 Re: loader problem/question in reply to dieselade, 04-08-2005 04:20:12
I'm not clear if you put forks on the bucket lip or if you take off the bucket & have a fork that mounts on the arm....
But, every inch farther out front a load is, you can lift that much less total weight. Measure from the rear pivot point of the arms to the mid-point of the load when it is in the bucket, & again when it is on the forks. A foot is a lot, 6" can make a big difference too.
Need to compare the weight of the bucket vs the weight of the fork set-up as well.
--->Paul
