Tool Talk Discussion Forum
Home made blasting cabinet
RustyFarmall
04-06-2005 12:24:22
Anybody have plans or ideas? Would like to build one that's large enough to put a tractor hood or gas tank into, maybe even an engine block? Sheet metal is very hard to find around here, so I plan on the actual cabinet being made of plywood. The frame would be steel for strength, but I need a sort of hopper in the bottom for easy clean out. Any ideas?
Slowpoke
04-09-2005 19:37:16
 Re: Home made blasting cabinet in reply to RustyFarmall, 04-06-2005 12:24:22
On my 1/2" plywood cabinet, I've used the rear window from a small camper shell, about 42-46" long x 12" hi. Side glass will work too. Old fireplace glass doors might be good. Depends on the cabinet size you want. Look for metal framed square corner stuff so sealing is easier. For a large cabinet, consider two sets of glove holes, so you can reach anywhere inside. I have a right hand side door. Old bed rails are good supports for the expanded wire floor, but don't try to weld them. Fasten them to the frame with the outside facing up so the sand runs off. Old washers and dryers have some nice steel sides that can be removed and used on the inside of a blasting cabinet. I'm not finished with mine, so I haven't used it yet.
Don L C
04-07-2005 20:42:31
How about a 55 gal. barrel cut in half, length ways or a 250 gal. heating fuel oil tank cut the same..... .
XXX
04-07-2005 15:08:20
I saw a nice professionally built one made from a home fuel-oil tank with a hinged lift door.
Glen in TX
04-07-2005 13:01:46
I got lucky and found a large cabinet military surplus. Check with your local surplus buyers for something. I've seen large cabinets made from old combine bins or large tanks too. You can make a trap door with spring and rubber gasket on bottom. For a better suction tube you can look at the TP one and make one like it from 1/2" electrical conduit and use clear acrylic hose to feed your gun. I just get a cheap shop vac to use on mine until the motor is wore out. Change the filters often or can double them too. I have seen guys clamp or wire the gloves to coffee cans too.
greywynd
04-07-2005 00:47:09
If you have access to rubber sheeting, you can fasten that inside and it will greatly extend the life of the wood/cardboard that you use for the cabinet.
Mark
RustyFarmall
04-06-2005 18:35:06
Thanks guys, you"ve given me some good ideas. I"ve already got the craftsman siphon feed gun and a bunch of large cardboard boxes. I"m the kind of guy that never throws anything away, so it looks like maybe the only thing I will need to buy are the gloves, and maybe a window, might be able to scrounge the window. Much thanks also for the link to ttp.
Davis In SC
04-06-2005 20:22:53
 Re: Home made blasting cabinet in reply to RustyFarmall, 04-06-2005 18:35:06
If you want some real heavy cardboard, find a plastic molding company. Plastic pellets come in a box called a "Gaylord" Some of them held over 2,000 pounds of pellets... They are made of the thickest cardboard I ever saw. Chances are they will give you an old one...
Bud in NC
04-06-2005 17:46:53
Could be kinda embarassing to admit, but mine is mostly cardboard & duct tape. I made an angle iron frame for the base, put some expanded metal in for a "floor" and stuck a 5 gallon bucket under the hopper funnel for the pick up tube. Yeah, it uses a real cheap suction type gun, too! One day when I have time I'll rebuild it with plywood and add a dust collector but in the meanwhile, I'm still finding modifications I want to make when I build the "real" one and except for the duct tape and my time this one was free. A resperator is a REAL good idea, too. It's a cheap, quick & dirty job but it makes a decent prototype so you can decide what you really need - a trashed refrigerator box is free - experiment and decide what you really need.
Bud in NC
04-06-2005 17:48:42
 Re: Home made blasting cabinet in reply to Bud in NC, 04-06-2005 17:46:53
Forgot to mention - the "window" in my prototype is a faceshield lens.
Larry806
04-06-2005 16:45:18
I bought a TIP kit with plans for the plywood one I thought it was cheap & easy. I'm very happy with it. I don't have there link but I'm sure someone here does
Charles (in GA)
04-06-2005 16:51:21
 Re: Home made blasting cabinet in reply to Larry806, 04-06-2005 16:45:18
www.tptools.com
Charles
Weirsdale George
04-06-2005 14:17:35
I made one out of 3/8 plywood and 2x4's. Inside dimensions something like 46"x30". The sloped front (probably 30 degrees from vertical) and the top are double-hinged so that both can be folded back allowing me to drop in heavy stuff with my engine hoist.
The gun is from a Craftsman siphon-feed setup. The bottom portion forms an upside-down pyramid with the siphon pickup at the apex so that the abrasive is constantly recycled.
dr.sportster
04-06-2005 13:25:54
I just gave the plans to Hobo on [usually on the Ford]section.I told hom when he is done to offer them on tool talk.However,the plans make one only 36"x24".doubling the dimensions on the plan wont really work right.The gloves and the window are available from TIP as is the dust collector. All the hopper is is a square plywood at the bottom with a hardware store hinge on it with some weatherstriping to seal it.Ive noticed a trailer door had a window that could work .In the plans the hopper is just 4 triangular pieces of the plywood with the bottom cut open.I did not make the plywood part myself,my father did that. The legs are just angle iron. The box is about 5/8" thick plywood.Anybody have any drafting software?I do but have no idea how to use it.Its called Design.Maybe you could mock up with cardboard.
Hobo,NC
04-07-2005 17:34:40
 Re: Home made blasting cabinet in reply to dr.sportster, 04-06-2005 13:25:54
Gott'em this week and have not had time to look'em over. Been busy in the shop I have had a run on engine rebuilds and replacments. I had a 2003 Cadi to replace the engine on and had to make a roller coster to handle dropin it out the bottom. Got the ide' from>Link
Roller>Link coster worked real good.
Hobo,NC
04-07-2005 17:38:10
 Re: Home made blasting cabinet in reply to Hobo,NC, 04-07-2005 17:34:40
third party image
Not a good pic but here it is
Don L C
04-07-2005 20:55:53
 Re: Home made blasting cabinet in reply to Hobo,NC, 04-07-2005 17:38:10
If you take that engine apart you will find abrasive inside.....been there....
dr.sportster
04-07-2005 19:44:15
Nice!
jhill
04-06-2005 12:41:10
TIP sells kits to make your own. It includes windows ,hoses, blast gun ETC. I have seen the cabinet made fron a combine tank or a 250 gallon fuel drum.
caseman2
04-06-2005 14:52:23
 Re: Home made blasting cabinet in reply to jhill, 04-06-2005 12:41:10
Explain TIP I don't know what these letters stand for?
Charles (in GA)
04-06-2005 16:50:27
 Re: Home made blasting cabinet in reply to caseman2, 04-06-2005 14:52:23
www.TPTools.com
Charles
