Tool Talk Discussion Forum
Air Compressor oil?
Dave F.
04-06-2005 09:24:22
I bought an 7hp.60gal. Coleman compressor. A while back from farm & fleet. The owners book susgested to use an multi weight compressor oil? In my old 2hp.compressor. the book said to use 30W non detg.oil. Is their something to these new compressor oils to justify the expense, or should. I just use the 30W Non Detg.oil. Thanks Dave F.
blast52
04-10-2005 04:30:04
 Re: Air Compressor oil? in reply to Dave F., 04-06-2005 09:24:22
Dave F.,
Is the compressor a rotary or a reciprocating(piston)?
Reciprocating types have a crankcase for the solids to settle as has been allready mentioned.
Non-detergent is approriate for this type.
Some of the models out now are rotary and reguire the special oils you mentioned.
HTH
Blast52
JACK E
04-08-2005 09:52:36
With air compressors, I was always told,that you use a straight weight non detergent oil. The reason for using non detergent, is, any solids do not stay in suspention. They fall to the bottom of the crankcase. Usually you do not have an oil filter on an air compressor, as you do on a car engine. So you don't want anything to stay in suspention in the oil and getting repeatedly pumped through the compressor.
Ryan
04-07-2005 10:17:04
What they are telling you is that yes you could probably put a cheaper oil in it. However, you probably spent a good deal of money on it? Why not make the one time purchase of the correct oil. What if something happens under warranty to the compressor, they would probably tell you that you were out if you didn"t use the correct oil. The compressor oil I got was clear, and pretty thin, the compressor did not take that much. My advice would be to get the correct grade of oil.
Ryan
Joe in Minnie
04-07-2005 06:08:21
OIL is OIL, what ever you use will work in your life time, "It's better then NO Oil at all"
Big Jim
04-07-2005 02:04:05
Compressor oil is a bit more expensive but since I can buy it at Walmart, I figure, 'what the heck' and use it
Don L C
04-06-2005 19:08:03
I bought a large Ingrasaw-Rand (can't spell)used from a gas station 28yrs.ago-----I can't believe it's been that long---I called the Rand Co. .....the man on the phone told me to use 10wx30w engine oil....I have checked it 3-4 times over the years, oil is still clean and the compresser ,no problems.....It is on and ready to use 24hs.a day, 365days a year,now for 27 years.
Jay87T
04-06-2005 18:03:10
whats so special about compressor oil anyhow? If you ask me synthetic would probly be the best choice.
Kevin Bismark
04-06-2005 17:30:28
The book with the new Ingersol Rand compressor we got last fall said the same thing but I have alway's just used 30W non detg in all the compressors with no problems
