Tool Talk Discussion Forum
Sump pump oil
led
04-04-2005 22:12:39
I took a submersal sump pump apart. Need to know what kind of oil used in electric motor. Oil keeps motor cool. I can take anything apart, its putting it back together that is tough.
thanks
led
kevin(ohio)
04-05-2005 06:08:05
 Re: Sump pump oil in reply to led, 04-04-2005 22:12:39
It depends on the manufacturer and model number. Most use a highly refined , non-inhibited transformer oil, (such as Shellflex or Texaco Code 600, grade 55, or WOCO). Some use a non-conductive turbine oil. List the make and model. Someone may be able to help. By the way, opening the motor usually voids the warranty, if it was still under warranty.
dilbert
04-05-2005 18:08:20
 Re: Sump pump oil in reply to kevin(ohio), 04-05-2005 06:08:05
Vegetable oil works fine.Right off the food store shelf.
