Tool Talk Discussion Forum
Pressure Washer
Tweeter
04-01-2005 12:50:53
I have a pressure washer that is a couple years old. It has a Honda 5.5 hp motor with if i can remember a DeVilbiss (is that right??) pump. It worked great for the past 2 years and today i got it out of the basement and it doesnt have the pressure it used to. It was spraying about half its normal pressure. Where i connect the gun hose to a quick connect the water comes out of there like normal with engine OFF and water supply ON. When i connect the gun hose and start the motor at high rpm, the pressure is weak and then sputters out to almost nothing then I turn the motor off. I unscrewed the gun from its hose and turned the water on and it sputtered out the end of the hose too. Everything seems fine until the part where the gun hose connects to the pump.
Big Jim
04-01-2005 19:52:48
 Re: Pressure Washer in reply to Tweeter, 04-01-2005 12:50:53
Every problem I've had is either a problem with the water supply or the detergent injector sucking air.
RayP(MI)
04-01-2005 16:59:57
First of all, pumps do wear out. Local Ace hardware man tells me he replaces his rentals every three years. I would make several checks before throwing out the baby however. How is the water supply? Filter at input of the pump? Any clogs or rust particles in the hoses, and other plumbing? How's the nozzle - recently replaced mine, it was visibly larger than the new one. Water had actually worn it out. Is it possible the pump itself is worn, defective, etc?
Tweeter
04-01-2005 22:33:33
 Re: Pressure Washer in reply to RayP(MI), 04-01-2005 16:59:57
How will I know if the pump is bad? The screen on the inlet is clean. The supply is excellent. I think that that problem is occuring before the gun nozzle. I do have a detergent port right before the hose connection.
