Tool Talk Discussion Forum
whats the best way to protect copper?
Jay87T
03-31-2005 05:40:52
hey guys I have some copper pipes Im tring to protect from loosing the nice copper finish, what do you think is the best way to protect them? a clear coat of paint?
Jay87T
Scott Green
04-02-2005 15:31:25
 Re: whats the best way to protect copper? in reply to Jay87T, 03-31-2005 05:40:52
I fabricate and install copper standing seam roofs. Some people like the copper to turn. For that , we don't apply anything. other people like the copper to stay copper looking. for the copper look , apply a product called "Copper-Doc". It comes in a kit useing a 3 step proccess. Step #1 is a cleaner Note: You can skip step one if the copper is new and already clean/shinny. Step #2 is a color locker Step #3 is a clear coat of some kind. The kit sells for around $150.00.
JerryU
04-01-2005 07:10:35
Polish it with something like Brasso and then coat with clear laquer. Musical instruments, which are brass alloy are made to shine that way.
JU
big jim
03-31-2005 21:15:38
Most home centers have spray cans of stuff designed to protect polished brass. Same stuff should keep copper from oxidizing.
John,PA
03-31-2005 13:03:28
I can remember years ago having indoor plumbing was a mere luxury.
Sometimes, especially in older log homes, the copper pipe had to be exposed, and people were quite proud of it.
Most of the older plumbers would steel wool the copper pipe and fittings that were exposed and coat them with a clear shellac.
I tend to use copper for making hand rails on some restoration jobs. After the copper is installed, I coat the tubing with clear polyurethene. (exterior grade).. It seems to hold up quite well.
HTH John,PA
MAC,IL
03-31-2005 06:26:05
Try some automotive clear lacquer.
upred
03-31-2005 20:10:27
 Re: whats the best way to protect copper? in reply to MAC,IL, 03-31-2005 06:26:05
have you tried Brasso? It is a brass cleaner and polish can be found at grocery stores the wife uses it on her copper bottom pots and pans
