Tool Talk Discussion Forum
Quality of Northern's 12-ton Shop Press
Kerwin
03-30-2005 19:37:13
Northern Tool has a 12-ton shop press that's pretty reasonable. Anyone ever use one to know what kind of quality it is? Thanks for the help.
lucasss
03-31-2005 19:09:14
 Re: Quality of Northern's 12-ton Shop Press in reply to Kerwin, 03-30-2005 19:37:13
i use a 25 ton napa press , its got a bottle jack on it. it wont get it with everything without some heat. so i would guess half the press wouldnt do much. lucasss
Bigdog
03-31-2005 14:09:45
Harbor Freight has their 20 ton on sale for $169 right now. Picked one up Tuesday.
JT
03-31-2005 06:28:52
unless you are not going to be pressing much, a 12 ton press is kinda light. 20 ton is better. and I am sure the price is not that much differant.
Bus Driver
03-31-2005 05:10:07
For a shop press, 12 tons is not very much. I have a 20 ton and at times wish it was a 40 ton. Consider something larger than a 12. We had a 450 ton hydraulic and 2 500 ton mechanical stamping presses where I was manager for 30 years. That is serious pressure.
Big Jim
03-30-2005 20:11:56
Can't say for sure about the Northern one but I have a Harbor Freight 20 ton and it works just great for my occasional needs. I looked at both a 12 and a 20. I decided that too big was better than too little and the price difference wasn't all that much. If you look at HF, remember they go on sale about twice a year.
jpuleo
03-30-2005 20:27:42
 Re: Quality of Northern's 12-ton Shop Press in reply to Big Jim, 03-30-2005 20:11:56
I have one, its fine for my use. The top cross bar flexes slightly when getting up there in pressure. I have never had another press to compare to, but mine serves my needs. I an pretty confident this is one item where cheep is fine.
Ron in Nebr
03-30-2005 23:32:54
 Re: Quality of Northern's 12-ton Shop Press in reply to jpuleo, 03-30-2005 20:27:42
The thing I've heard recently(probably here) is that with the price of steel these days you can't hardly build one yourself for what these sell for.
And one other good thing- it's made out of plain old iron so if you ever should need to, you can grind a bit of paint off and weld on some reinforcements where needed.
Trump
03-31-2005 04:32:40
 Re: Quality of Northern's 12-ton Shop Press in reply to Ron in Nebr, 03-30-2005 23:32:54
I was in Northern Tool several weeks ago looking at retractable air hose reels. Noticed that some of the items there are the same that HF has,but more expensive.
