Tool Talk Discussion Forum
propane how much pressure
coup
03-30-2005 17:53:18
what pressure is generally on the small propane bottles,medium size and larger tanks? i was just a wondering.
Russ Smart
03-30-2005 18:15:47
 Re: propane how much pressure in reply to coup, 03-30-2005 17:53:18
If you do a search on propane you will get more information than you can ever understand! All propane would have the same pressure in the tank and it depends on the temprature, it will run from 0 psi at -40F to 300 at 125F!
txblu
03-30-2005 22:41:01
 Re: propane how much pressure in reply to Russ Smart, 03-30-2005 18:15:47
With that said, you need a 2 stage regulator on your cutting rig to keep from having to constantly tweak the gas pressure to the torch.
Mark
