Tool Talk Discussion Forum
need some welder advice quick!
J Puleo
03-30-2005 14:38:08
I have a big old 1960's craftsman 220v ac stick welder. I can buy a 220v Dayton 3z564 ac/dc arc welder for cheep. I called the guy and he said its about 1.5 feet wide by 2 feet tall. sounds kind of small. I was wondering if anyone has some infor on this unit. The fella is asking $50 and I always herd DC is better.
Thanks
Joe
T_Bone
03-30-2005 23:05:57
 Re: need some welder advice quick! in reply to J Puleo, 03-30-2005 14:38:08
Hi Joe,
Any DC machine that welds half way decent will bring $50 easy. Typical 20% duty cycle for the smaller machines. If the machine is not running or you can't try it out, it may scrap for $15 if it's no good, so not much risk.
From the pic it appears to be made by Century. I've used a couple Century machines and was impressed with the arc stability for a cheap machine.
T_Bone
txblu
03-30-2005 22:48:57
What's the amperage capacity. At 220 ac input I guess it will be at least 200 A ac and 100 A dc.
The dc gives a smoother, cleaner weld and is easier to control. Makes great welds on thin stock.
In ac the flame actually starts and stops 120 times per second (too fast for you to see but it does). With dc it stays lit. Also there is a big inductor (coil) in the dc rig that makes for a constant energy supply.
Short side is the dc rectifiers get hot so you have to reduce the work function in a little unit so that they don't get overheat and short out (melt).
But so what. If you are like me you are doing this for yourself and you get it done when you get it done.
Haven't seen the welder but the price sounds right.
My last welder purchase was a Miller 200/100 ac/dc and it is small like that but I gave bout $250 for it new. Works great for me after only having ac for so many years.
Mark
MAC,IL
03-30-2005 14:57:47
Link
big jim
03-30-2005 19:54:15
 Re: need some welder advice quick! in reply to MAC,IL, 03-30-2005 14:57:47
WOW! Less than 20 minutes. Was that quick enough?
J Puleo
03-31-2005 14:29:10
 Re: need some welder advice quick! in reply to big jim, 03-30-2005 19:54:15
thanks guys I think Ill buy it, It has all the leads, so your right, not much risk at that price.
