Don't understand. What is a carbon tipped drill? I believe you mean a carbide tipped drill. If so, carbide is about the best readily available material you can use to drill steel. If carbide tipped drills are not working, the problem might be the type of point. For many applications, a split point drill is self centering, thus, it will keep the point from "walking" over your workpiece and help you to get an hole started. Most cobalt drills have split points. You might use a smaller split point drill to get a starter hole. Then a left hand drill might be able to penetrate and break loose your studs. If the left hand drill still doesn;t do the job, try the 4 flute stud removers/drill extractors by Armstrong, Williams and others. You tap these tapered fluted extractors into the drilled hole and turn with a wrench. Use rust penetrating products if necessary. This should solve most problems. If this doesn't work, I guess you will have to use a torch to heat and extract. Good luck!
