Hi Terry, Changing a rear tractor tire is pretty easy, alot easier than some small tires. I use a wood splitting wedge to break the bead. I place the wedge next too the rim lip as vertical as I can get it and smack "one time" with a single jack, then move 3" and repeat. Move about 18" and the bead pops inside. At first it doesn't look like the bead has moved at all, but it does. Sometimes you have to use a 50% dawn dish soap and water mix to make it slip. I then use one 24" crow bar and one 12" crow bar to work the tire off the rim. Reverse to reinstall. Work a short section of bead over the rim at one time. To large of "bite" will tear the bead and make it difficult to work the bead inside/outside over the rim. Keep the bottom of the tire to the center of wheel as much as you can as this part of the rim has a smaller diameter. Sand the corners round and smooth on the wedge and 7/8" crow bars. I got real good quality China crow bars at HD for about $8eh. I get patchs and glue at Wal-Mart, cheaper than Napa. I use a 2" wire wheel on a die grinder to buff the tube/tire patch area then use NAPA liquid buffer before applying the patch. I use a window screen tool too smooth out the patch. Takes me about an hour to patch a tube and reinstall it and I'm a gimper so I'm slow. It would take me 2hrs to pull the rim and get it into town. They want $75 a tire for a service call here plus repair cost. I just can't pay that. T_Bone
