Tool Talk Discussion Forum
Pigeon Control Worker?
Rod in Smiths F
03-26-2005 13:32:41
I was jointing my way through a pile of lumber in a the ex-haymow I use for lumber storage when I felt eyes on the back of my neck. You know the feeling. I had to look for quite a while before I found the source of the stare. Way up on the hay fork track hunched a very, very large racoon, gazing balefully down at me.
Apparently he/she disapproved of the noise of my jointer and moved as far away from it as she could get.
This solves a mystery. Up until this winter I've been plagued by pigeons parading back and forth on that track, bombing my lumber piles. While using up my basswood I twice had to change the planer blades because of the grit.
But there haven't been any pigeons in the mow this winter. To get that fat she must be a good mouser, too.
My enemy's enemy is my friend.
Mark - IN.
03-27-2005 06:41:33
 Re: Pigeon Control Worker? in reply to Rod in Smiths Falls, ON, , 03-26-2005 13:32:41
Once had to replace a 25 pair phone cable for some old 1A2 equipment at an asylem that some racoons had chewed through. Well, used armored PIC (thich black coat) this time, and had to crawl on my belly the length of the crawl space under that long building wing with the racoon(s) down there. Only saw one pirched up on some water pipes, and it didn't bother me, and I didn't bother it, and if it'd been mad, I'd been in trouble cause wasn't much room to move around. So, I dragged this cable the length of the building and shoved about 20' up through a hole I drilled through the concrete floor, and I crawled tie-wrapping that cable out past that racoon looking at me, me looking at it. WOW, made it - not exactly. When I got upstairs to terminate my cable, there was my 1/2' hole drilled through the floor, but no cable. What the heck happened to my 20' of cable that should be sticking up through the floor???? There were two male residents (nuts) standing there, and one comes over to me and says "Mikey's (the other guy) afraid of snakes, but I'm not and shoved him back down his hole". I had to go get a nurse to lock up Mikey and his pal, then had to go back down there with that racoon to shove my cable (snake) back up the hole. Honest to God it happened.
Happy Easter, Mark
Easy
03-26-2005 19:17:24
Strange how things work. I spent all day today replacing the soffit on my pole barn. A section collapsed a coulple days ago. Basically full of raccoon crap. Really disgusting. Bushels and bushels worth. Some mummified baby coons. And 1 fat female coon. Now dead. Birds are a PIA. Raccoons are truly disgusting. Think about it - a very large rodent. Easy
Davis In SC
03-26-2005 19:47:30
 Re: Pigeon Control Worker? in reply to Easy, 03-26-2005 19:17:24
Another thing about Coons..... . There are some that carry Rabies, but they are immune to it... We have some here..... ....
03-27-2005 05:00:58
 Re: Pigeon Control Worker? in reply to Davis In SC, 03-26-2005 19:47:30
Talk about disgusting. One of our friends at the marina restored an old Hattaras motor yacht and upholstered the interior with white denim. Then a racoon pulled open a screen and ransacked the place.
Seems the first thing a racoon/burglar does is find a flat surface and have a bowel movement. Then the culprit walks through it every time it moves across the boat.
Everybody on the dock kicked in and still the cleanup took half a day.
I live-trapped and executed the large female. Her kits have never come back.
About the rabies: two years ago in our area the Ontario Ministry of Natural Resources hired every trapper and ex-conservation officer they could find to trap and innoculate racoons for rabies. The idea was to create a 50 mile buffer zone of innoculated racoons to keep out the deadly U.S. strain of rabies. One contractor caught and dosed sixteen coons, one fisher and two cats in our 20 acre woodlot. He said the fisher caused the least trouble, the tomcats the most.
Chances are excellent that the coon in my barn has an ear tag, but I don't know if I want four or five little ones snooping around.
Marfak GREASE..John,PA
03-26-2005 15:04:24
Years ago our large aircraft hangar had lots of birds that would build nests in the roof trusses.
Birds and airplanes generally do NOT MIX, especially in the SPRING.
After many attempts to discourage the birds from nesting, an old WWI veteran came by and guess what?
He mounted a small piece of plywood in each corner of the hangar. The plywood was located up in the roof trusses. On the plywood he put a big GLOB of Marfak grease.
For some reason, this fixed the bird problem. OWLS didn't like it though.
The ole vetran said " birds don't like greasy feet!
Hope this helps. John,PA
BillD 1
03-26-2005 17:00:50
 Re: Pigeon Control Worker? in reply to Marfak GREASE..John,PA, 03-26-2005 15:04:24
Amen to birds and airplanes Spent hours in the spring fighting bird nests in inlet ducts Finially made all new duct covers to block them out They could build faster than I could tear out
Tim Shultz
03-27-2005 11:06:46
 Re: Pigeon Control Worker? in reply to BillD 1 , 03-26-2005 17:00:50
I use a daise 880 to get rid a both coons and birds, ain't seen neither for quite a while!
so I'd say it works good!
Lou
03-28-2005 13:02:18
 Re: Pigeon Control Worker? in reply to Tim Shultz, 03-27-2005 11:06:46
Im in upstate NY, a couple of years back we had a canadian plane flying grids droping baited medicine to our Racoons. Lou
