: : : I have a leaking gasoline tank on a small : : Briggs and Stratton engine. The tank is metal and : : is about 4" square by 12" long. The leak is along : : the seam. : : I want to try and repair it by heating the tank with : : an acetylne torch and laying a bead of solder along : : the seam. My torch instructions warn "never use : : on any container which has held gasoline" because : : of dangerous vapors. : : I emptied the tank about a week ago, the cap is off : : the top, the valve is out of the bottom, but it : : smells like a fuel container and I expect it well : : smell for sometime to come. : : Do I have anything to worry about heating this thing up? : : Any advice appreciated! : Get a hold of an old soldering iron heat that to melt the solder. or buy some of the tank sealer they sell or just get another tank or make an appointment with your undertaker It's possible to repair a tank with a torch. The trick is that you first drain it, rinse it out a few times, and then fill it with exhaust gas from your car's muffler. You wouldn't need a acetylene torch, though, a propane torch would work just fine. The trick is to get your surfaces very very clean before you solder. I just repaired leaks in both a diesel tank as well as a gasoline tank and I'm here writing this! ~martin
