Tool Talk Discussion Forum
remington chain saw ignition parts
del howard
03-26-2005 06:18:38
can anyone help me find ignition parts for a mity mite model-mma2 serial-vk3312? the saw is in realy nice shape and i would like to get running again. thank you for any help you can give me
jdemaris
03-26-2005 07:33:08
 Re: remington chain saw ignition parts in reply to del howard, 03-26-2005 06:18:38
Those parts are easy to get, you just have to match them up. Remmington used REPCO (R.E. Phelon) or Wico ignition parts - these same parts were used on many other saws and types of power equipment. If you pull the flywheel, and look at the parts, you can find them in many catalogs. NAPA, for one, has a pictorial catalog for small engine ignition parts. Some of the newer Mightymites used a one piece points and condensor asssembly - same as small Homelites and Stihl used - NAPA # 7-1030. Older ones have the points and condensor separate. It's easy to match the points with the photos in the catalog, and the condensor usually has numbers on it. The flywheel will have the name of the magneto company on it.
