Tool Talk Discussion Forum
Foot pounds / Inch pounds
BUDD
03-24-2005 14:05:26
What is the conversion to go from foot pounds to inch pounds on a tourqe wrench?
Thanks BUDD
dr.sportster
03-24-2005 14:40:10
 Re: Foot pounds / Inch pounds in reply to BUDD, 03-24-2005 14:05:26
1foot lb is 12 inch pounds example: 120 inch lbs divided by 12 gives 10 ft lbs.Another example;5foot lbs-- 5x12 equals 60 inch lbs.Read the torque wrench instructions good info.
JCH
03-24-2005 14:07:36
1 foot pound = 12 inch pounds
BUDD
03-24-2005 14:39:01
 Re: Foot pounds / Inch pounds in reply to JCH, 03-24-2005 14:07:36
Well I can not believe it is that simple!! emagin that
Thanks BUDD
dr.sportster
03-24-2005 16:55:17
 Re: Foot pounds / Inch pounds in reply to BUDD, 03-24-2005 14:39:01
Hey BUDD ,what calls for the inch lb. spec.?Just curious.Or maybe you where just wondering,nevermind.
bcPA
03-25-2005 10:45:40
 Re: Foot pounds / Inch pounds in reply to dr.sportster, 03-24-2005 16:55:17
cummins injectors are the only thing I really needed a inch lp wrench for. I think It was 60 inch pounds when the injector was being fired.
BUDD
03-25-2005 03:46:39
dr.sportster I am replacing the rear main seal on a 304 jeep motor. I always over tighen the oil pan bolts, so I thought I would use a tourqe wrench. The book calls for 7 foot lbs. I will use the inch pund wrench now.
Thanks all BUDD
dr.sportster
03-25-2005 07:22:53
 Re: Foot pounds / Inch pounds in reply to BUDD, 03-25-2005 03:46:39
Careful with the toorque wrench if they are 1/4-20s hard to use a torque wrench on a 1/4-20 gives a false feel sometimes a snapping sound.Of coure it depends on the size of the torque wrench.
Jerry/MT
03-24-2005 19:23:43
Preload on wheel bearings are normally speced in inch-pounds.
