Tool Talk Discussion Forum
compressor motor
jwh
03-22-2005 18:11:12
I bought a used 60 gal.,3 hp 2 stage comp today. The tag on the motor says 230v-3450rpm-1 ph-amb40c and a16. What size wire from the comp to the breaker and what size breaker should I use? Thanks, Jim
dr.sportster
03-22-2005 19:04:37
 Re: compressor motor in reply to jwh, 03-22-2005 18:11:12
Using 12awg is not a code violation most would probably be fed by 10awg due to the fact that its on the line between 12and 10.Not all services are 230 volts so at 220/208 it would up the amp spec to the 30 amp circuit using ten.At the 208 volt service most equipment rated 230 still works fine but if any had problems it would be a compressor.[ an oversimplified math calculation says thats not a true 3 horspower motor]so dont worry.
Bob
03-22-2005 18:37:41
A 3 HP single phase motor with a FLA of only 16 Amps. Interesting!
Anyhow, with a FLA of 16 Amps, #10 wire should be more than adequate, unless it it a very long run from the breaker box! With #10 wire, the max size breaker you can use is 30 Amps, which SHOULD start the compressor.
Joe(TX)
03-24-2005 13:49:39
 Re: compressor motor in reply to Bob, 03-22-2005 18:37:41
Compressor motors are not rated the same as normal motors. They are rated HP is at peak load instead of at continuos load. At continuos it would be more like 1 1/2 hp. That is why the amperage is lower.
buickanddeere
03-22-2005 23:03:14
If that motor had capacitors to get power factor back to unity. Then 3.0HP would be possible if the motor was 58% efficient. A stretch for a single pahse motor but not impossible
