Tool Talk Discussion Forum
Welding helmet question
Jay87T
03-22-2005 14:34:43
hey guys Im now in the market for a new welding helmet, does anyone here use a auto darkening helmet are they worth it? or should I just get a regular one?
Steve Crum
03-23-2005 09:08:54
 Re: Welding helmet question, funny you should ment in reply to Jay87T, 03-22-2005 14:34:43
Just bought this, This morning to go with the new Miller syncrowave. looks like a full featured unit, and it accepts a diopter set. (Very important for me anymore)! But sit down to write the check!
[IMG]http://img216.exs.cx/img216/8199/dcp00020qu.th.jpg[/IMG]
Don L C
03-23-2005 07:40:42
 Re: Welding helmet question in reply to Jay87T, 03-22-2005 14:34:43
Get the automatic darhen one..... I love mine ..... Ibought it from HARBOR FRIEGHT..... It has been working OK now for about 1 1/2 yrs.....
TimV
03-23-2005 06:03:09
I love my auto-darkening helmet. While I'm no professional welder, I've been welding off and on for 20+ years, and they're the best thing I've seen come along in a long time. I've got a cheapie, but it's done everything I've asked it to do, including a few long welding sessions with no flash burn afterwards. If you've got the money, by all means get a Huntsman, Speedglas, Jackson or similar, but even a cheaper one will do wonders for your welding. The one thing I've noticed with the cheaper ones is that the dark-to-light transition takes longer (and is non-adjustable) for the cheaper helmets. It's only a matter of a second or so, but it's noticable.
fred kobs
03-23-2005 02:07:36
If you use one for an hour you'll be hooked or is that spoiled! I love my speedglass...only drawback I've noticed is the batteries need to be warmed up on the coldest of days. Probably would have been a non-issue for me but had to work in the brother in law's shop and couldn't get above 25 degrees some days. Get a good one and enjoy!
Weirsdale George
03-23-2005 01:06:57
If you get a "solar powered" one, make sure it has replacable batteries. The permanent battery in mine dies at about 18 months -- opened up the cartridge, removed the battery and wired in a double AA battery holder.
e
03-22-2005 17:24:15
I've got a speedglas (I think it's the 9000X) auto darkening helmet and love it. It has side shields which give the user peripheral vision(this has saved me from crashing into things on a number of occasions) You may not need one quite so fancy, but none the less, auto darkening is the way to go.
JT
03-22-2005 16:32:22
You will think you have died and gone to heaven. Don't buy the cheap, cheap ones, I do not know how well they block welding light. We got ours from the welding supply place %189.00. My .02 worth.
Model_T
03-23-2005 12:16:54
 Re: Welding helmet question in reply to JT, 03-22-2005 16:32:22
Well put JT. I don"t know how I would get along without one now.Just think about welding under a truck, overhead, exhaust repair, stitch welding just to name a few places they work. I almost did"t get one though. I was helping a friend years ago and he insisted I use his.After welding all day and walking outside I could see a little orange spot in the snow.It didn"t burn my eyes but I didn"t like that. Later another weldor convinced me to try his and I reconsidered one. I bought a Jackson 3N1 executive but have found that I never use the grind or torch buttons. Billy
harvey2
03-22-2005 15:54:47
Well worth the money, they work great.
Dale in WV
03-22-2005 15:16:44
I got one. Love it. Not a top of the line, but neither is my welding. Got it at the local Tractor Supply when the gift cards allowed a prolonged visit w/o wife's scrutiny.... Between myself and brother-in-law we share a welder and hmmm he's got the helmet now too!!
Jon H
03-22-2005 15:42:46
 Re: Welding helmet question in reply to Dale in WV, 03-22-2005 15:16:44
Would not be without one. I love not having to constantly flip the helmet up/down and being able to instantly set the degree of darkness for the job.
Bought one from Harbor freight for $60 on sale. I bought on advice from this site saying to buy a cheap one and see what features you want/need before spending big bucks. This one does everything I want it to do,so not interested in a higher buck unit. Had this a year and it seems very good. The instructions said it may not work at low temps,but the only difference I can see is that it goes from dark to light a bit slower when very cold.
Lumpy
03-22-2005 19:34:20
 Re: Welding helmet question in reply to Jon H, 03-22-2005 15:42:46
I've been welding every day now for a while with stick mostly, and mig. I purchased a cheap solar type electronic hood for the shop. Mostly because they all thought it was a have to have item. For small mig jobs it might be ok although I think it's a bit slow and I think I'm catching some flash from it. It is good for items that require accurate weld starting locations. Or holding items to tack in place. Also it was represented as a number 11 shade when in reality It's a 9 or thereabouts. Again it was a cheap-o. Really the pits when you grab the grinder because it wants to darken.
I use a standard inexpensive hood with a 2x4 flip up shade. I Change out the lens shade for the job between a 10 and a 12. Only use the gold type shades (plastic is fine) and replace clears very often.
Maybe if I find an auto shade helmet I like I might use it, but I have no issue with the manual hood, and when it gets all dirty I toss it and start over with a new one for like $25.
I just hate waking up at 3am with the feeling of sand in my eyes. (a sure indication of exposure)
My best welding shop purchase lately was some 1.5 reading glasses in safety glass version with side shields.
