Do you want a stationary or a portable unit? Buy as big as you can afford. You will be surprised what you will find to do with the air. Air tools such as die grinders and sanders use alot of air. If you have a shop/garage and a good source of electric power, buy a stationary unit, two stage, 80 gal tank, with a 5 RUNNING horsepower motor. This will give you 17 to 19 cubic foot a minute of air flow and you won't be overworking the compressor. It will also run a blast cabinet if you decide to get one for cleaning up parts. Here is a link to what I am suggesting..... . I'm not endorsing the brand, just that this is the size/capability compressor I'm suggesting. Link You get what you pay for. I struggled along for years with too small of a portable, and finally realized what I needed, to run a blast cabinet especially but for everything, was lots of air, more than enough, and bought a 7.5 running horse, 80 gal, two stage, that produces about 23 cfm at 100 psi. I'm darn happy with my purchase and wished I'd done this years ago. Whatever you do, don't waste your money on one of those oil free, fast running units. they are VERY noisy and get very hot and don't last well. Pay close attention to horse power, smaller units, most portables, are listed as PEAK horsepower, this is bogus, and if it says 5 hp PEAK, its really about 1.5 horse RUNNING. Most two stage units from 5 running horse up are given in RUNNING horses. What you are really interested in is CFM of delivered air flow. Two stage units generally run 175 psi tank pressure, you regulate it down to 100 psi for air tools. This gives you much time between cycles of the pump, while single stage units generally only go up to 125 psi and even with a big tank such as 60 gal, cycle more frequently and cannot keep up as well with high air flow demands. Charles
