Tool Talk Discussion Forum
Exhaust manifold Tap
Freud
03-22-2005 14:01:08
I was told by a friend of mine awhile back that I can retap the threads in my exaust manifold where the pipe comes out of the manifold and clamps to the muffler. I have a 1952 Super M and the threads are corroded pretty good and they simply need to be rethreaded. Problem is: where on earth can I find a 2.25 inch pipe thread tap? Any help would be appreciated.
jakej
03-23-2005 08:37:18
 Re: Exhaust manifold Tap in reply to Freud, 03-22-2005 14:01:08
I rented one from a rental center for $5 for an Oliver manifold. Gave the threads a heavy coat of anti seize no more rust or corrosion.
RustyFarmall
03-23-2005 05:06:38
I found mine at the Northern tools store, set of three in a wooden box. Seems like somewhere around $40 for the set, might be higher now. I have used the 2 inch size extensively. It works good.
MAC,IL
03-23-2005 06:17:27
 Re: Exhaust manifold Tap in reply to RustyFarmall, 03-23-2005 05:06:38
Yep I saw those on northern for under 50 bucks. Otherwise those can be expensive, 200 bucks anyway for just the size you are needing.
T_Bone
03-23-2005 02:08:25
Hi Freud,
You can use a piece of threaded 2" pipe with deep slots cut into the threads with a 3corner file, about every 1/2" or so.
Be sure and try your home made tap in a regular 2" pipe fitting to make sure it starts and cuts correct. You do have to clean it more often than a regular tap.
If the threads are too bad it might require a tap but I've used this method alot on other projects with good results.
T_Bone
dr.sportster
03-22-2005 18:18:12
Freud,MSC1800645-7270 2 11 1/2 imported is 89.56 Greenfield is 260.70 there are others listed.Dont forget pipe sizes are trade size not actual ruler measurement.[I looked up what George said]
george md
03-22-2005 21:43:06
 Re: Exhaust manifold Tap in reply to dr.sportster, 03-22-2005 18:18:12
dr,
Glad someone is chacking up on me . :-)
george
dr.sportster
03-24-2005 15:01:29
 Re: Exhaust manifold Tap in reply to george md, 03-22-2005 21:43:06
No George not questioning or checking up on you .I just knew you stated the correct size he wanted.T- bone has the cheapest and easiest solution.Make you own thread chaser from pipe.
george md
03-22-2005 17:53:08
Freud,
It's 2 inch pipe - 2 -11 1/2 NPT
george
