Tool Talk Discussion Forum
Vise Stand?
John in Ct
03-21-2005 10:16:18
Where can I get a new good stand to mount my vise on? I bought a 8" Snap-On vise, maybe 5 years ago and never really used it because I mounted it on my "Clean Bench" area of the shop. I would like to move it to where I can really use it for welding, grinding, banging etc. Thanks!!
HJP
03-22-2005 17:29:49
 Re: Vise Stand? in reply to John in Ct, 03-21-2005 10:16:18
I have a RIDGID vise stand. really do not know how old it is.I have a pipe vise mounted on it and use it just as you plan on doing
NC Wayne
03-21-2005 20:39:13
Mine's mounted to the back bumper of my 32,000 lb service truck...No matter how hard I try I've yet to get it to move. Seriously I've seen alot of vises mounted using a post welded to the top of a rear brake drum off a road tractor. The drum alone weighs a good bit already so if you'd weld a plate around the back side and fill it with metal scrap packed in or simply fill it with concrete it ought to provide a fairely stable base.
Bus Driver
03-21-2005 17:07:42
I built mine many years ago from scrap metal and concrete. Steel weighs about 4 times as much per cubic foot as does concrete, so the interior is mostly steel. Mine looks like concrete, as the outside is just that. During vigorous use, even a 500 pound stand might move around. So mine weighs 2000 pounds. It just sits there during use.
bob
03-21-2005 16:29:59
I have a couple of stands made from 30 gallon drums filled with leftover redi-mix concrete.
I embed some threaded rod, using a pattern to set the rod ends to fit the vise.
When I need to move one, I just clamp a log chain in the vise, and lift it with a "cherry picker" or a loader.
Needless to say, they provide good support for the vises.
Dug
03-21-2005 21:40:21
 Re: Vise Stand? in reply to bob, 03-21-2005 16:29:59
bob,
Great idea. I have been trying to come up with something for my vise, also. Your idea sounds perfect. Solid, yet still moveable.
Thanks,
Dug
dr.sportster
03-21-2005 14:04:14
A truck in front of me today had one mounted on a small Knapp gangbox where it opens like a cabinet[truck said pump and valve repair].Thats no good for gravel driveways or dirt outside though.I have one on a large 3foot high pipe flange for welding,but thats not real mobile either.How about on an outdoor workbench with a cover on it.A blacksmith probably used a cut off stump for vises and anvils.
MAC,IL
03-21-2005 12:10:45
CAnt answere that one John, most store bought ones to me are inadequate. If you are handy and have the equip, I would make one to suit my needs. Probably cheaper in the long run and I think you would be more satisfied with one you made. We always made ours out of used pipe or square tubing. Then used a steel plate on the top. Then bolted it to the floor. Size depends on the work area that you need. Dont take long and is not difficult to fabricate.
ScottP
03-21-2005 11:57:50
John
I used a piece of 6" square tubing for mine. I have a 6" Wilton vice and an 8" Ridged pipe vice. So, I welded a plate with a piece of recever tubing weld in it to the top of the square tubing. Then I made plates with insert tubing that bolt to the vices and then slides down into the top of my post. I made one for each vice. Lift one off, drop the other in. Make sure you use the heavest material you can get for the post to eliminate flex. It hepls to keep it as short as possiable.
Scott
JMS/MN
03-21-2005 11:39:22
Might be kind of tough in most parts of CT, but hang around a JD dealer until he needs to replace a rear axle housing of something like a 4430. Big chunk of cast iron that makes an excellent stand for an anvil. When the bearing goes out and chews up the housing, the replacement costs a few hundred bucks in a salvage yard and the bad one is scrap cast price. Sounds like personal experience, huh? Others just use a big stump.
JMS/MN
03-21-2005 11:41:47
 Re: Vise Stand? in reply to JMS/MN, 03-21-2005 11:39:22
Rats!- I was still thinking of the ANVIL thread!
