Tool Talk Discussion Forum
best way to clean hyd pump
diggerdave
03-21-2005 08:59:51
hi All- Ive a older belt drive hydraulic snow plow pump. Still works great after another tough season but i noticed a hairline crack on one of the resovoirs welds that leaks fliud. Ive taken the pump off the truck and emptied the fliud. Anything i should or should NOT put in there to clean out any remailing gunk?? What works best to clean her all up so the weld can be fixed? thanks diggerdave
big jt
03-21-2005 10:06:13
 Re: best way to clean hyd pump in reply to diggerdave, 03-21-2005 08:59:51
I like the spray on carb cleaners for that sort of cleaning. Just spray and wipe with a shop towel. For final clean up spray and let air dry. Works well for prep for using silicone sealants.
JM2CW
jt
