Tool Talk Discussion Forum
Wiring for status
Regor
03-21-2005 06:33:51
I would like to add a status light on the exterior of my pump house- when the pump is running, the light is 'on'. What's the best way to do (wire) this?
Thanks,
RogeR
Thank you, gentlemen
03-22-2005 06:22:39
 Re: Wiring for status in reply to Regor, 03-21-2005 06:33:51
Thanks for the info, guys.
RogeR
David - OR
03-21-2005 08:28:07
Most pumps, except for the shallowest of wells, are powered by 240 volts. There may or may not be a neutral available for using a 120 volt fixture.
If you use a 240 volt bulb and a 240V rated fixture, and wire the fixture between the switched side of the pair of contacts in the pressure switch, you will not have to try to sort out the circuits running to the pump and pumphouse.
Alternatively, if the pumphouse has internal lighting and/or ordinary 110V receptacles, there is most likely a neutral available. But to use it, you will have to sort out whether the pump circuit has its own neutral or whether there is a separate circuit for the lights/receptacles.
T_Bone
03-21-2005 07:08:16
Hi Regor,
Pull the hot lead for the lite from the T1 connection on the pump switch.
When the contactor trips to power the pump it will also power the lite.
T_Bone
