Tool Talk Discussion Forum
Shelf Life??
Jay87T
03-20-2005 06:30:18
does Argon/co2 mix have a shelf life?
T_Bone
03-21-2005 07:01:19
 Re: Shelf Life?? in reply to Jay87T, 03-20-2005 06:30:18
Hi Jay,
A sort of shelf life as the two gasses will seperate after time with the Ar gass settleing to the bottom of the cylinder where the dip tube picks up the Ar gass first. The gasses themselfs do not change and will last for ever.
I thought I'd cut a fat hog and buy one tri-mix cylinder for all my use and after 10yrs or so I used the Ar gass leaving behind some Co2 and He which didn't work well as a cover gass, (out of correct volume).
That's why I suggested 100% Ar gass as a one only gass to keep around.
T_Bone
David - OR
03-21-2005 14:42:33
 Re: Shelf Life?? in reply to T_Bone, 03-21-2005 07:01:19
T_Bone has way more experience with welding than I do, however I will point out that CO2 has a density of 1.96 g/l whereas argon is 1.78 g/l. (Helium is 0.179). If something will "settle out", wouldn't it be the heavier CO2?
Actually, no. Since all three materials are gases, even at 2000 PSI, they should fully diffuse and intermix with each other within the cylinder. That's what gases do. There should not be any "settling" or separation of the components within the tank. This would be violation of the second law of thermodynamics.
This is a good thing -- otherwise all the CO2 and argon in the atmosphere would settle to the earth's surface, leaving us to suffocate.
There is a secondary effect that may explain T_Bone's empirical observation. The rubber hose connecting the tank to the MIG machine establishes a diffusion membrane. The more energetic (lighter) gas molecules are more likely to diffuse across this membrane than the heavier ones. Over time, this will allow the gas mixture to change its composition. This is most pronounced with the helium (just look at how fast an He filled toy balloon goes flat). But over enough years, the AR will difuse through the hose faster than the CO2, leaving the mixture relatively richer in CO2 than it started. This is not a violation of the second law because the tank + hose does not form a closed system. (The enrichment effect can be reduced by keeping the tank valve closed except when using the machine.)
Gas diffusion is a known method for separating two materials close to each other in density. Just ask the Iranians and North Koreans...
Nolan
03-23-2005 03:31:22
 Re: Shelf Life?? in reply to David - OR, 03-21-2005 14:42:33
"...they should fully diffuse and intermix with each other within the cylinder. That's what gases do. There should not be any "settling" or separation..."
Ever notice how methane and radon gas sink, and helium or hydrogen ballons rise? ;-)
T_Bone
03-23-2005 01:44:40
Hi David,
The second law of thermodynamics states:
"heat flows from a higher temperature source to a lower temperature source"
The settling of the gas would not occur in the open atmoshere but would occur with-in a vaccum or pressure vessel. If the gases wouldn't seperate then we wouldn't have the refrigeration effect than makes some of our refrigeration equipment work.
Example:
The typical RV refrigerator uses this therory. Here we combine hydrogen gas and ammonia gas and heat that solution and drive off the hydrogen gas thus leaving behind the ammonia gas to cause the refrigerating effect then condense the gases to recombine the gases to once again restart the refrigeration cycle.
In the above example we did not violate the 2nd law of thermodynamics to seperate or recombine the gases but used this Law to obtain the refrigerating effect.
This gas seperation effect can best best explained by Dalton's Law that states:
"The total pressure of a confined mixture of gases is the sum of the pressure of each of the gases in the mixture"
The law further states:
" That each gas behaves as if it occupies the space alone"
Moisture content of each gas would also have a effect on the seperation/combining process.
One should never leave any gas cylinder valve open for storage. This is for safety as well for gas leakage.
T_Bone
