Tool Talk Discussion Forum
Batteries for a Ford 7.3L
JonathanGPS
03-18-2005 19:34:48
I just bought a 1997 F350 with a 7.3L Powerstroke Diesel. Within the next couple of months I am going to need to invest in some batteries due to the age of one of the current batteries. I am planning to replace both bateries. What brand and size of batteries would be best for good service in this truck. Thanks for your opinions.
T_Bone
03-20-2005 00:34:55
 Re: Batteries for a Ford 7.3L in reply to JonathanGPS, 03-18-2005 19:34:48
Hi Jonathan,
Can't go wrong with MC battery's. I get a e-mail flyer from Ford at $59.95eh twice a year. Register at there website to get there specials, about 4 e-mails per year.
On ther other hand, I agree with B&D and am going to replace mine with Optima yellow tops when the time comes as I plan on keeping my 7.3 for 30yrs or so. They cost about $130eh and you will need the extra battery hold downs as there a little smaller than the MC battery, (usually NC from a Optima dealer). They exceed the CCA of the MC battery requirement.
I expect 10yrs plus out of the Optima's in the AZ heat (from my sons past useage). We normally get 3yrs out of a good lead acid battery.
T_Bone
buickanddeere
03-19-2005 22:14:37
Optima Yellow Top Industrials or the largest Odyssey AGM battery. Are you in a southern or Northern State?
jjgmc
03-19-2005 12:35:18
Go with the optima red top batteries best one built nuff said.
jeffcat
03-19-2005 10:39:18
Go to the INTERSTATE BATTERIES web site and look up Optima Batteries in the tech information. I have three of these in items around here and have hooked several friends and neighbors when I start and they don"t. GREAT batteries! They have 1000 amp crank at 75 degrees and over 800 at freezing.Jeffcat PS DON"T drop a wrench across the terminals! It will melt!
jack-Iowa
03-19-2005 07:42:18
got a 91 and I use the 1000 cca at sams best price and they seem to hold up.
caseyc
03-19-2005 05:51:11
go down to your local ford dealer and get a pair of BXT-65-850's. they are the best batteries for the buck and have a three year free replacement. we charge 79.95 per battery. if your dealer isn't as friendly then interstate is also a good choice also but are a bit spendier.
casey in SD
Engineer20
03-19-2005 15:18:10
 Re: Batteries for a Ford 7.3L in reply to caseyc, 03-19-2005 05:51:11
Casey is right!
Go get the original Motorcraft replacement. My 1996 F-250 went 7 1/2 years on the original battery. My 1992 t-bird went 7 years on the original Motorcraft battery.
txblu
03-20-2005 05:50:09
 Re: Batteries for a Ford 7.3L in reply to Engineer20, 03-19-2005 15:18:10
Now that you are counting, my Dodge is a'98 with the orig battery; so I gainin on you. Grin.
Mark
txblu
03-19-2005 06:10:19
Another option is the OTR truck batteries. I use them exclusively for my tractors with 00 cables.
They're 900 cca size 31 (same physical size as a 27 trolling motor battery) with 3/8 stud terminals. Truck dealer buys them by the skid getting a volume price which he passes along to you at $59 ea.
Mark
