Tool Talk Discussion Forum
emerson electric motor questions
riverbend
03-18-2005 16:56:27
1. A while ago someone posted a problem with an electric motor that would not come up to speed. I have an old 1/3 hp Emerson Electric motor (Multi - Duti) that does the same thing. The solution was cleaning the contacts in the centrifugal switch, but I don't remember what should not be used to clean them (emery cloth?).
2. Did the old Emerson motors just have bushings instead of bearings ?
Thanks
Greg
MAC,IL
03-18-2005 17:58:17
 Re: emerson electric motor questions in reply to riverbend, 03-18-2005 16:56:27
Metalic emery cloth is a no no. I always used fine sandpaper or a burnishing tool. Most Older motors of that HP had bushings, easy to tear down.I always marked the position of the caps to the body before removing end caps. Make sure it is not just dirty and also make sure the Spoon or centrifigal switch assembly is free.
Dick2
03-19-2005 04:01:57
 Re: emerson electric motor questions in reply to MAC,IL, 03-18-2005 17:58:17
Those little sandpaper sticks that the womens use on their fingernails work good to clean the contacts.
