Lawn roller
dave
02-14-1998 13:14:50
I want to build a roller to tow behind my 50 8n, need some ideas on how big to build it. I'm thinking 5 or 6 feet wide by 2 or 3 feet in dia. any ideas ? I have 4 acres that I mow and will be rolling.
thanks, dave
Al
02-14-1998 21:37:51
 Re: Lawn roller in reply to dave, 02-14-1998 13:14:50
: I want to build a roller to tow behind my 50 8n, need some ideas on how big to build it. I'm thinking 5 or 6 feet wide by 2 or 3 feet in dia. any ideas ? I have 4 acres that I mow and will be rolling.
: thanks, dave
I have seen rollers fabricated from the tank out of a water heater. Fill it with sand for weight; weld a short section of pipe to either end to serve as an axle; then build a 2 X 6 frame with holes drilled to accommodate the pipe/axles. It's not too fancy, but it does the job and it costs next to nothing.
dave
02-15-1998 18:00:54
 Re: Re: Lawn roller in reply to Al, 02-14-1998 21:37:51
: : : I want to build a roller to tow behind my 50 8n, need some ideas on how big to build it. I'm thinking 5 or 6 feet wide by 2 or 3 feet in dia. any ideas ? I have 4 acres that I mow and will be rolling.
: : thanks, dave
: I have seen rollers fabricated from the tank out of a water heater. Fill it with sand for weight; weld a short section of pipe to either end to serve as an axle; then build a 2 X 6 frame with holes drilled to accommodate the pipe/axles. It's not too fancy, but it does the job and it costs next to nothing.
I did just that, welded one together out of an old 40 gal. hot water heater tank, My kids tow it around the yard with an old garden tractor. I want to build a "BIG" one for my n to tow over the whole 4 acers . I'm thinking rolling will cut down on the wear and tear of my 6' finishing mower and should cut down on mowing time.
Indian Guy
02-18-1998 12:46:43
 Re: Re: Re: Lawn roller in reply to dave, 02-15-1998 18:00:54
: : : : : : I want to build a roller to tow behind my 50 8n, need some ideas on how big to build it. I'm thinking 5 or 6 feet wide by 2 or 3 feet in dia. any ideas ? I have 4 acres that I mow and will be rolling.
: : : thanks, dave
: : I have seen rollers fabricated from the tank out of a water heater. Fill it with sand for weight; weld a short section of pipe to either end to serve as an axle; then build a 2 X 6 frame with holes drilled to accommodate the pipe/axles. It's not too fancy, but it does the job and it costs next to nothing.
: I did just that, welded one together out of an old 40 gal. hot water heater tank, My kids tow it around the yard with an old garden tractor.
: I want to build a "BIG" one for my n to tow over the whole 4 acers .
: I'm thinking rolling will cut down on the wear and tear of my 6' finishing mower and should cut down on mowing time.
Living in the oil patch I look to the wells and stuff for solutions to material problems. So here goes nothing (again) well casing material (pipe) is all over the place out here and if a body could get a couple of 4 - 6 foot lengths he could weld plates on the ends after centering a hitch pin on the end and rig up a V shaped frame to pull it around. You could fill it with sand or water if you put in a bung. MIght even be able to gang them up.
Dusty
03-08-1998 11:55:14
 Re: Re: Re: Re: Lawn roller in reply to Indian Guy, 02-18-1998 12:46:43
: : : : : : : : : I want to build a roller to tow behind my 50 8n, need some ideas on how big to build it. I'm thinking 5 or 6 feet wide by 2 or 3 feet in dia. any ideas ? I have 4 acres that I mow and will be rolling.
: : : : thanks, dave
: : : I have seen rollers fabricated from the tank out of a water heater. Fill it with sand for weight; weld a short section of pipe to either end to serve as an axle; then build a 2 X 6 frame with holes drilled to accommodate the pipe/axles. It's not too fancy, but it does the job and it costs next to nothing.
: : I did just that, welded one together out of an old 40 gal. hot water heater tank, My kids tow it around the yard with an old garden tractor.
: : I want to build a "BIG" one for my n to tow over the whole 4 acers .
: : I'm thinking rolling will cut down on the wear and tear of my 6' finishing mower and should cut down on mowing time.
: Living in the oil patch I look to the wells and stuff for solutions to material problems. So here goes nothing (again) well casing material (pipe) is all over the place out here and if a body could get a couple of 4 - 6 foot lengths he could weld plates on the ends after centering a hitch pin on the end and rig up a V shaped frame to pull it around. You could fill it with sand or water if you put in a bung. MIght even be able to gang them up.
I had a fuel oil tank that I wanted to get rid of, so I took my air chisel and cut the flat parts out of it and welded it back togeather.
I would think that if you wanted anything bigger it would be better to gang several togeather.
