Tool Talk Discussion Forum
Broken Footer
Dan Hill
03-17-2005 06:38:03
My father is having a home built with no basement. The floor is a concrete slab. The builders poured the Slab on a day that it snowed 8 inches. As expected, the slab is in poor shape. After they had finished the framing and dry wall, the footer snapped in three places causing the foundation to collapse at one corner of the house. The builder told me that it was caused by unstable soil and that this can be fixed. I do not know what day the footer was poured. My guess is that it was sometime in December or January. Can anyone educate me as to what would cause a footer to snap?
andy/tn
03-19-2005 21:04:21
 Re: Broken Footer in reply to Dan Hill, 03-17-2005 06:38:03
Pictures of the project sure would be helpfull-my email is open [email protected] please send me some.
O.K. here we go. I didn't see what state you are in but most of the southeast goes by sbcci southern building code. According to that code your footers need to be atleast 8" deep (I think). According to me 8" deep sucks and is not thick enough in most places (I am a contractor and build many houses and have seen too many other peoples footers fail). I pour 18" deep and 24" wide footers with 4 sticks of 1/2" rebar (two at top and two at bottom). Some say that I spend too much $ on footers but then again I never have any problems. I don't know if your on city sewer or septic tank but if you are putting in a tank make sure they dig the hole atleast 12' from the house. Often a thin footer will crack a while after the septic tank is installed and guess where the septic usually is? It is usally out from the corner of the house and about 8' from the footer. When you dig a 9' deep whole that close to a footer the ground is weakened under the footer. My footers will not give cause it's thick, wide, and most importantly it has 4 sticks of rebar in it. If your footer has settled you really need to get this problem fixed or it will always be a problem. I have seen sheetrock crack because of sucky footers settling. Have you ever seen a brick home with a crack or seperation running up the side or end of the house? Ever wonder why the brick cracked or seperated? Answer: sucky footers! The foundation is the most important part of a house. If anything else in the building process is screwed up it so much easier to fix than the foundation. You have gotten some really good advise from others here and with pictures we could tell a lot more. I am sure that your builder is going to feed you a big line about how it is not his fault and can't be helped - that's bullcrap and he knows it. Would you spend thousands buying a new car that didn't run? Me niether. Don't spend thousands a new house that is not right.
Sid
03-18-2005 21:33:41
The unstable soil is not excusable it suggest that someone cut corners when doing site work getting ready to pour footers. Another possibility that I have seen done befor is the footers could have been pour on top of snow. There is no excuse for either of these two.
Bud in NC
03-18-2005 04:16:28
Might be a good time to hire an independant house inspector who"s familure with local building codes and conditions - just to protect your investment.
Davis In SC
03-17-2005 21:21:12
I am not real knowledgable about construction, but right now, your Dad is in a situation that needs to be be taken care of in the correct way.... If builder does a half-a$$ fix, it will be tough to get any remediation if problem recurs in a few years. I would suggest that an engineer be brought in to evaluate & suggest how to fix. In this area, builders declare bankruptcy, on a regular basis, & start up the next day using another name. Just something to think about..... .
Mark - IN.
03-17-2005 17:22:11
Warranty work? I hope so.
Mark
Vern-MI
03-17-2005 13:19:32
You mentioned "Slab, Footer and Foundation". Are the foundation and footer one and the same? Is the slab still in one piece and the footer which runs around the perimeter dropped in one corner and separated from the slab? If that is the case then dig out the dropped and broken footer back to the good, not separated section. Then drill into the good footer and epoxy rebar into the good footer and run it the full length of where the new footer will be repoured. The new footer will have to extend out from under the slab and alongside and under the existing good footer for at least four feet to assure bond integrity and rodent barrier. Reform that area and repour it with at least three parallel 1/2 inch rebars in the new section. The failure leads me to believe that the ground had some backfill which collapsed and caused the problem. That needs to be fixed by digging down to virgin soil.
Dan Hill
03-18-2005 04:30:39
 Re: Broken Footer in reply to Vern-MI, 03-17-2005 13:19:32
This is what I can see from the dug out area.
There is a footer that appears to have been made with poured concrete using no forms but the soil. Then there are three layers of concrete block on top of the footer. The whole section of the house was then filled with pea gravel. The slab was then poured with what I believe is the concrete block being use as the forms for the slab. There appears to be no cracks in the slab, but there is a crack that is seen from the inside of the house. I looks as though it is where the slab meets the concrete block foundation.
VaTom
03-18-2005 05:02:51
 Re: Broken Footer in reply to Dan Hill, 03-18-2005 04:30:39
Hi Dan,
Trench forming of the footer is very common here. Works fine. Using block as the floor form is also common. It always results in that crack you saw. No problem. My all-concrete house has both.
Vern-Mi is right. The broken footing didn't have sufficient earth support, likely fill. Fill could have worked but it would have needed compaction under skilled direction. That's where soil engineers come in.
As it's now a little late to compact, as Vern suggested,I'd be digging down to undisturbed soil for the new footing. If it turns out that there was no fill under the failed area, you REALLY need a soils engineer.
Another potential problem is that some of that pea gravel under the slab probably went in on fill too. In time it won't support the slab. Might be a future problem, might not, depends on the strength of the slab and how far it will span.
To fully understand the scope of the problem you need to find out if there was fill and what portions of the house were built on it. Assuming fill, the contractor clearly didn't know how to deal with it and all areas over fill should be suspect. Not all problems show up so fast.
Sorry to be so negative, but I deal with concrete houses that put large pressure on the bearing soil from roofs weighing 3-400 tons. Something down there must be able to support the weight. Your Dad's(?) house is only going to get heavier as it's finished and moved into, putting more pressure on whatever's under it. Really bad place for any movement.
Good luck.
Dan Hill
03-18-2005 05:22:18
 Re: Broken Footer in reply to VaTom, 03-18-2005 05:02:51
Thank you VaTom,
We will be meeting with the builder sometime next week to review their solution to this problem. I now have better insyte as to the cause, fix and future of this issue.
VaTom
03-18-2005 06:08:49
 Re: Broken Footer in reply to Dan Hill, 03-18-2005 05:22:18
Good luck Dan.
The old conventional wisdom was to spend whatever was necessary on the roof and the foundation. Anything left over was spent in the middle.
Unfortunately, this attitude has mostly died, in favor of floor plans.
Strong recommendation to physically be there for the excavation for the new footing. You should be able to see a color change in the dirt when they get to undisturbed soil. And I sure hope you don't see top soil.
This builder has a potentially major problem. Make sure it remains his. Ask around about a soils engineer.
Dan Hill
03-22-2005 11:06:41
 Re: Broken Footer in reply to VaTom, 03-18-2005 06:08:49
VATom,
We had our meeting with the builder. We have been given a new lot to start over.
I want to thank you for your help in educating me. I used some of what you had written and I believe that it made a big impact in my argument.
Dan
Dan Hill
03-22-2005 11:05:35
VATom,
I want to thank you for your help in educating me. I used some of what you had written and I believe that I made a big impact in my argument.
Dan
VaTom
03-22-2005 15:19:38
 Re: Broken Footer in reply to Dan Hill, 03-22-2005 11:05:35
Wow! You're certainly welcome.
You must have also done your part to get a start-over. Amazing what a little knowledge can do, eh? And now I'll bet the builder will make absolutely certain the house is properly constructed to ensure he doesn't go through that again. You have a reputation!
One never knows when advice is offered how it'll work out. This is far beyond my wildest expectations. Very glad it worked out for you. Did they admit there was substantial fill under the house? Let me guess, you mentioned a soils engineer?
Assuming the other lot has undisturbed soil, not an old landfill or somesuch, there shouldn't be any problem. Good luck.
dr.sportster
03-17-2005 07:41:49
First you pour the footings withh rebar and ground wire hanging out then you pour the slab.Sounds like an area without building inspectors.When that happens here its jackhammer time.
dr.sportster
03-17-2005 19:25:20
 Re: Broken Footer in reply to dr.sportster, 03-17-2005 07:41:49
I should shut-up since Im only on the jackhammer side once it dries.And the wet side when someone else pours it on top of my pipes for duct bank.
LUCASSS
03-17-2005 06:57:36
EVEN THOUGH the slab may be 3 or 4 inches thick , the footer around the parimeter should be 18-20 inches deep or below the frostline for your area.if the slab is poured over the footer or both as one peice you will get cracks between the thicker footer and the slab. ive seen alot of guys short people on concrete to make a buck.did the build the walls on just a slab with no deep footer? slab construction is the cheepest way but not the best in my opinion.
