Tool Talk Discussion Forum
Welding cast aluminum
Mike from cny
03-16-2005 16:37:41
Well to start, I rebuild carrier refrigeration compressors (for trailer units etc). Not sure if anyone is familier with these. Anyhow, Built a compressor with a brand new block. Pressure testing revealed dry nitrogen was leaking right through the cast aluminum block. It was only a small pock mark where it was leaking, about the size of a ball point pen tip. The material thickness is about 1/4in in that particular area. Was thinking maybe grind the area out a little bit, then buy some of the aluminum wire for my mig welder, (I have 2 a hobart handler 135, and a millermatic 35 which is 220.)
I'm kind of leaning torwards the hobart as the one to use. Anyone think this can be done?
I can weld mig and stick pretty good, on steel anyways. Would appreciate any tips on welding aluminum as well. What do you guys think?
Thanks for the help guys!!
ebbsspeed
03-18-2005 06:17:37
 Re: Welding cast aluminum in reply to Mike from cny, 03-16-2005 16:37:41
Mike, assuming you'll have access to both sides of the case that the leak is in (I suspect you would disassemble the compressor to do any welding on it), and given all of the concerns about the aluminum being inpregnated with a sealer, or destroying a coating on it, could you possibly take the low-tech approach and drill a hole through the case where the pock-mark leak is, and then put a small stainless steel screw, with an appropriate material rubber o-ring for sealing, through the hole, a nut with some locktite on the other side, and use it. Assumption is that there would be enough room on the inside of the case for the head of a small screw. If not, you might be able to tap the hole and put a screw in it from the outside, with an appropriate thread sealer. Since this pock-mark is only the size of a ball point pen tip, and you've got a quarter-inch thick casting, I'd think a small 6-32 screw would be plenty big to seal it, and not damage the integrity of the case at all.
Bill WI
03-17-2005 07:33:00
Before you ignor epoxies you may want to check out www.sealfab.com/castings. They've been doing this for over 15 years up here on new castings. I would think a good industrial supply would have an answer. Your casting may have been coated and by welding could open a new can of worms. My $.02
Bob - MI
03-17-2005 05:45:06
I have sold castings for many years. The fact of life in aluminum castings is that there is always some degree of porosity in them someplace. The type of porosity and severity are often directly tied to the process that they are made with. The alloys used will vary with the process choice too. My assumption is that this case is an aluminum die-casting. If so, this is likely a 380 or 360 alloy. 360 has a finer grain structure and is better suited to pressure tight applications. If you choose to weld this you should see if you can get some compatible rod for that alloy. TIG will be the way to go.
On the manufacturing side of things, that case should have been pressure tested at some stage in the process. What you have is a leak test failure part that somehow got mixed in with acceptable components. I would see if the manufacturer (not tha casting supplier)can help you with this problem. I can tell you that getting leakers mixed in with good parts is a bad thing for a supplier to do and there are lots of precautions that are supposed to be in place that are intended to prevent this.
One word of caution here, castings are often allowed to be impregnated with a resin-based sealer to stop leaks. If your case has been impregnated it will out-gas significantly when you weld it and it may be tough to get a good bond. Impregnated parts are often grey in appearance. Of course if it"s been painted it"s tough to tell.
T_Bone
03-17-2005 00:31:59
Hi Mike,
Mig would be a poor welding process choice as you get cold lapp the first 3/8" or so.
I'm with George,md as Tig would be the best choice. Pay close attention to what George has to say as he's surley one of the best craftsmen around by just looking at his work on his website.
Another choice would be Oxy/Acet with using low heat. Here too many weldors use too high of heat thus causing more problems than they solve.
Whatever the process choosen, practice on a scrap block would be a good idea before making the final repair.
Aluminum cast is also known of tubing, leaking from another area following a tube with-in the cast to the exit point.
Grinding a slot would be a good idea but don't get carried away on depth, about 1/2 of total thickness, as welding AL it's very easy to drop your puddle thru or onto the floor.
I'm very supprised at the Carrier blocks having this problem. Carrier has always been a quality product.
I've included my comments from a previous thread:
You can use oxy/act to gas weld AL. You can use AL stick rod with the flux left on or use a scrap piece of AL with a flux made from borax with alcolhol added to make a paste and just dip the filler rod into the flux when needed. If you keep your filler rod with-in the gas flame zone then a flux is not needed. Be sure to remove all flux when done welding as AL will continue to oxidize if the flux is left on.
There is a couple tricks to Gas or Tig welding Al. As your heating the base metal you will notice the weld puddle will start swrilling and that is the correct time to add filler rod and move backwards/forwards. I like moving away from my weld puddle as you can see how much filler rod needs to be added. A split second latter wrinkles appear with-in the weld puddle and if you don't quickly remove the heat or move forawrd then your weld puddle will end up on the floor.
If you Tig weld SS you will also notice this swrilling action of the weld puddle. On SS that means you have just achived 100% penetration of the base metal and if your heat(amps) are set correct then you can hold this weld puddle and let it develope to the maxmium width wanted (1.25 times the thickness the base metal equals the weld puddle width your wanting) until your weld puddle drops to the inside then adding filler rod and moving forward at the same time thus achiving and inside weld puddle the same width as the outside weld puddle. The inside weld bead material is from the base metal dropping thru and you add the filler rod for the build-up of the outside weld bead. Thats how you achieve a weld that looks the same on the inside as it does on the out side.
So if you don't want 100% base metal penetration so it "sugars" the inside, don't let your weld puddle swrill.
Sugar means the inside weld bead oxidizes without using a purge gas usually argon at about 5cft/min. I explained this process as it can be applied to any weld puddle control therory of any type of base metal and is the best example a welder will have to "see" the "controlled" process in "slow" motion.
You can also use a chill bar clamped to the backside of your weld joint base meterial.
A chill bar is a thick piece of metal, usually 1/2" x 2" wide copper, used to draw the heat thru the base metal but hold the weld puddle from dropping thru and the weld puddle will not stick to the chill bar base metal. On welding AL you can use a piece of "clean" steel, no scalling, SS or CU. On welding Copper a SS chill bar works best. On welding carbon steel a CU, AL or SS chill bar will work.
While welding AL you will notice a black oxide scale appear on the surface and the weld puddle becomes very difficult to control. Stop and remove this black oxide with a new SS wire brush or new grinding wheel. It's very important to use new wheels as if the wheels had beem used on Cu or Fe you can't get rid of the black oxides.
Filler rods also need precleaned with emery paper or scotch-brite to remove oxides exspecially while Tig welding. On Fe filler rod, clean filler rod too bear metal as well as clean base metal 1" on either side of the weld joint or it will cause prosisity in the weld.
Pure argon can be used for a cover or purge gas but is very expensive when welding Fe comparred to Co2. On 316 SS a tri-mix needs to be used. I like using a 75%helium/25%argon gas mix for Mig or Tig welding Alumnium as the arc will alot hotter with helium gas. Although the 75%argon/25%Co2 will work your weld will have prositity included with-in the weld along with alot of AL splatter on the surface.
T_Bone
Mike from cny
03-17-2005 22:20:18
 Re: Welding cast aluminum in reply to T_Bone, 03-17-2005 00:31:59
Link
Theres a pic of the compressor. It isnt actually a Carrier block, its aftermarket. Carrier prices their OEM parts are outrageous, following closely behind Cat. If you look at the pic, that compressor would go for around 5K new from Carrier, and a reman is around $3000. However they reuse all parts possible, like used crank, rods, pistons, valve plates get resurfaced and oil pumps reused. We use all NEW aftermarket parts except the block, heads, oil pan, front flange etc. I think I may try gas welding it on an old oil pan and see how it turns out. As always guys thanks for your help.
george md
03-18-2005 23:18:15
 Re: Welding cast aluminum in reply to Mike from cny, 03-17-2005 22:20:18
Mike,
I beem thinking about your endeaver with oxy/acet on the alum, I think you will need more preheat with o/a than with tig because it will take longer to heat the weld area with a torch. I have done some o/a on alum , mostly thin sections , but some castings. and on the castings the work was on ears or corners and edges. The rod from Postle for castings was a litle bit
stiffer when melted than the rod for thin sections.
It also had the flux inside the rod . I still think tig with plenty of preheat is your best choice.
george
george md
03-16-2005 22:56:21
Mike, With the crankcase pressure and the expansion
and contraction due to temperature change ,the
epoxy doesn't stand a chance. I believe TIG would be better than MIG, you can
watch the puddle and see what's going on without
adding filler material,then add as needed.
I don't know about the cast al in those blocks
but I have had trouble with cast al oil pans for
cummins and cat. Welding cast al is much like welding cast iron but will warp much worse. I
would try tig and if it cracks either in or along
side the weld , I would try enough preheat to get most of the expansion out then weld .
george
ebbsspeed
03-16-2005 19:43:41
I'd put a little epoxy over the pock mark and be done with it. Clean it good first, make sure it's a little rough so the epoxy has something to bite on.
Davis in SC
03-16-2005 18:49:10
Not trying to be smart-a$$, but if block is brand new, will manufacturer make good & replace it ???
Mike from cny
03-16-2005 20:59:25
 Re: Welding cast aluminum in reply to Davis in SC, 03-16-2005 18:49:10
as far as warranty goes, I know I would be mad if I got a defective case, however these are new aftermarket cases, and we've had ALOT of problems with the aftermarket lately, plus we have 2 built, both leaking right though the case, must be realy porous. Not sure about the epoxy either, Refrigerant can get in and through the damndest places from what my boss says. Plus he got quite a few of these and not sure how much trouble it would be to warranty them anyways. I appreciate all the help so far. Thanks!
Davis In SC
03-16-2005 21:08:08
 Re: Welding cast aluminum in reply to Mike from cny, 03-16-2005 20:59:25
Sounds like maker of castings has a problem with porosity. I would get in touch with them, to see what is up. it might be that porous castings cause slow leaks, even on units that test good now. If this happens, it could really hurt the reputation of the Co. you are working for.
wdtom
03-16-2005 18:07:31
I am no welder. I used to work at a company where we did MIG aluninum extrusions and a couple of times castings. I think you could expect a good repair as you are only doing a small spot. You won't get into shrinkage problems. Try the MIG on some similar scrap, you can MIG aluminum just fine. We used argon I believe as we used that for TIGing stainless. I don't think we had seperate tanks, but it was a while ago. For just one spot one time you might take it to a welding shop where they would know what and how, no question. Shouldn't cost all that much, especially if you need to buy much to get into it.
dr.sportster
03-16-2005 16:52:55
Although I went to welding school twice ,apprenticeship and was a weldor I have Migged if thats the term about three times in my life, not owned one.Ive used it to fill in stripped out holes in a crankcase with oxy/acet preheat of case.This is what I think a weldor would do.drill a small hole cut a small alum rod plug it into the hole and mig all around.The alum wire wont be to much different than steel wire .I think but I did use alot of preheat.Argon or helium should work .Wheres T-bone.
