Tool Talk Discussion Forum
Solution to getting rid of paint thinner stain com
Illinois_jim
03-16-2005 13:16:05
Hello guys, I mostly lurk here. but I do have a question. I recently moved into a house in which the previous owner left a 55 gallon drum full of old paint thinner, stain, and some other oil based products (no auto fluids). It seems no one wants to "recycle" anything oil base. I'm looking for a cheap, but enviromentally safe way to get rid of this. Can it be burnt in an waste oil burning heater? I was tossing around the possibility of running through a small motor, but I doubt that would work.
Any Ideas guys?
Thanks in advance.
Big Jim
03-16-2005 22:38:07
 Re: Solution to getting rid of paint thinner stain in reply to Illinois_jim, 03-16-2005 13:16:05
Our county offers a hazmat service. You call them up to make an appointment then go to a special facility and unload. There is a charge but it is pretty minimal.
Davis In SC
03-16-2005 19:25:59
Do you mean it is all mixed in a drum ??? Or in smaller cans in a drum???
il-jim
03-16-2005 20:52:13
 Re: Solution to getting rid of paint thinner stain in reply to Davis In SC, 03-16-2005 19:25:59
Yes, its all mixed in one drum,
Midwest redneck
03-16-2005 15:45:07
I know that the tree huggers association would shoot me for saying this but if you live in a rural enough area could you dump a few quarts in an empty drum with some yard waste over the course of a few weekends and get rid of it that way. And no body would be the wiser, or see that black smoke.
Vern-MI
03-16-2005 13:37:56
The local Waste Management Company told me they would take any oil based VOC material if it was first poured out onto cardboard or paper and allowed to dry. That's what I did but I only had about 30 gallons to get rid of. Sounds like you have a bigger project.
I wouldn't attempt to burn it because of all the black sooty smoke it would produce.
il-jim
03-16-2005 20:53:11
 Re: Solution to getting rid of paint thinner stain in reply to Vern-MI, 03-16-2005 13:37:56
how long did that take to dry? how much cardboard did you have?
Vern-MI
03-17-2005 02:20:12
 Re: Solution to getting rid of paint thinner stain in reply to il-jim, 03-16-2005 20:53:11
The oil based paint took about 24 hours and the lacquer paints were dry in a couple of hours. I reused the cardboard by applying successive coats after the first coat dried. I used cardboard boxes from small appliances, refrigerators, TV's, stoves that we had purchased so it really didn't take that much. Don't do it on top of grass because it will kill the underlying vegetation from the heat of the sun and the cardboard covering the ground for a few days. Son-in-law said it wouldn't work but then began to bring over his old paint to get rid of it as well.
Bob
03-16-2005 14:25:58
Wouldn't pouring thinner or whatever on cardboard be risking spontaneous combustion?
Vern-MI
03-16-2005 16:15:38
 Re: Solution to getting rid of paint thinner stain in reply to Bob, 03-16-2005 14:25:58
The sheets of cardbosrd were laid out in the yard and the paint and thinner were spread over them and they were left to dry. It was no more hazzardous than painting anything else would be.
Chester
03-18-2005 08:35:37
 Re: Solution to getting rid of paint thinner stain in reply to Vern-MI, 03-16-2005 16:15:38
If it is used paint thinner it can be re-used. Let it sit for a few weeks and it will clear itself, leaving the crud in the bottom. Seems to do a better job second time around when used for thinning paint, cleaning small greasy parts and hand spraying it on larger items to de-grease before power washing. Try a sample before you discard..... might be re-usable for something.
