Tool Talk Discussion Forum
Blast cabinet plans
dr.sportster
03-15-2005 17:04:07
Found the plans for the blast cabinet.It takes two pieces of plywood not one as I previously stated.It is 24"x34.It can be made with a circular saw, hand saw, drill,and tape measure.They are copyrighted1983 so I cant copy them but you can have the original if you pass it on to others that may want to build it.All my stuff got wiped out on computer the other day.When I get help I will straiten out my email. I know why its not working now.
Slowpoke
03-29-2005 11:15:13
 Re: Blast cabinet plans in reply to dr.sportster, 03-15-2005 17:04:07
I have constructed a large (52x32x24 approx.) cabinet from plywood. It's not finished yet, but the point is I used a junk camper shell rear window hinged to the face of the cabinet. It's tempered glass, an expensive item. I got glass protector sheets from TIP(Trumans). The window can be from the side of the shell if you want a smaller cabinet. Look for an older shell that has square corner windows and may be free or little money. The cabinet also has a side door, and double armholes.
dr.sportster
03-17-2005 10:33:04
Ok Hobo,you have got the plans but email your address you want them sent to.
dr.sportster
03-16-2005 04:40:47
If you want the plans use this email my wife [email protected]
