Tool Talk Discussion Forum
Skinner adjustable lathe chuck
dr.sportster
03-15-2005 06:02:42
Cleaning up my shop over the weekend I came upon an old lathe chuck made by Skinner that is a three jaw,but has a switch knob on the back that allows each jaw to be adjusted individually or in the other position,all to tighten together at once.Its not the style that fits my Clausing but looks like a nice chuck.Is this sort of a compromise between a 3 jaw and a 4 jaw?
greywynd
03-16-2005 00:09:17
 Re: Skinner adjustable lathe chuck in reply to dr.sportster, 03-15-2005 06:02:42
Most of those chucks can have the backing plate changed to one that will fit the lathe that you have. Take a look and see if the threaded portion (for mounting) will come off. Then you just buy a new backing plate to fit the spindle of your lathe.
Mark
dr.sportster
03-16-2005 16:17:18
 Re: Skinner adjustable lathe chuck in reply to greywynd, 03-16-2005 00:09:17
Greywynd,Thanks for the suggestion but since the knob is on the back it would ruin the chuck.It really wont accept adapters or Id try it on my lathe.Good suuggestion for chucks in general.Ive had a cam loc for an old Pratt&Whitney lathe mated to a face plate in the past.A little runout but worked ok.
dr.sportster
03-15-2005 16:41:44
There is no way it will fit on my Clausing which takes L1 or L0,I forget.But there is also no adapters as far as I know.The Skinner is 2 1/4 x8 tpi.[female]I would have to check that again cause no glasses but If anyone can use it on their lathe let me know-just pay shipping.E-mail takes me a couple days to figure out but its open.Condition looks good ,not sure how old it is.
dr.sportster
03-15-2005 16:44:22
 Re: Skinner adjustable lathe chuck in reply to dr.sportster, 03-15-2005 16:41:44
E mail didnt open anybody wants it say so and Ill figure it out.E-mail might work now.
ScottP
03-16-2005 14:53:07
 Re: Skinner adjustable lathe chuck in reply to dr.sportster, 03-15-2005 16:44:22
Dr.sportser If you still have this chuck I could use it on my 11" Logan. Send me an email with your address and the amount to ship to 95688 and I'll send you my address and some money.
Scott
dr.sportster
03-17-2005 10:36:00
 Re: Skinner adjustable lathe chuck in reply to ScottP, 03-16-2005 14:53:07
Scott need your full address for shipping estimate.Your zip gives two different towns on the ups site estimator.Got it packed up good.Almost forgot chuck key but its in there.
dr.sportster
03-16-2005 16:11:26
My wifes email is on the thing about the blast cabinet but here it is [email protected] Mines not working or Im doing something wrong.You must hit the shift key to make the dash lines.First thought it was 2 3/8 but its 2 1/4x8 tpi.
dr.sportster
03-15-2005 16:46:16
Try again but if it does not work just tell me you would like it .
J. T. L.
03-15-2005 16:24:59
I have 9" Skinner 4 jaw like that. The jaws are normaly independent, but all 4 can be locked in together to work like a normal 3 jaw chuck. My chuck was on an old index head. It has the "knuckle buster" locking screws on it. Circa 1900, give or take 10 years I would guess. I set it up to fit on my 11" Logan lathe. I do still use it from time to time.
Davis In SC
03-15-2005 15:13:50
I have seen those chucks, but never used one. Now there are 3 -jaw chucks that allow the main body to be adjusted to center by the use of set screws. Then you just use as a regular 3-jaw. I have one made by Buck. Works well for repetitive parts of the same diameter. Bad part is that it has a slight imbalance at high speeds.
