Tool Talk Discussion Forum
picture of engine
Coloken
03-13-2005 15:41:00
If I can get the link to work; here is a picture of steem engine I made with a minne lathe. The cylinder and crank, I used the milling attatchment.
Kenny
dr.sportster
03-16-2005 10:28:05
 Re: picture of engine in reply to Coloken, 03-13-2005 15:41:00
Nice.Took a lot of skill.You must get Home Shop Machinist.
neowert
03-13-2005 16:13:30
How did you cut those curves and angles with just a vice?
Coloken
03-13-2005 16:54:10
 Re: picture of engine in reply to neowert, 03-13-2005 16:13:30
Cylinder was square stock. Hold in vice of milling atachmet, then advanced across angle cutter rotated in headstock. Piston/connecting rod is turned fron round rod. then held in mill vice to put the little "flat" where the crank pin is. Crank "throw" is flat piece, surfaced in mill, then held on arbour/spindle and rotated to get curve. You see..you never get enough of "tooling" (boreing bars, angle cutters, milling cutters, etc.) for machine tools. Lots of fun.
Kenny
