Tool Talk Discussion Forum
question about spray painting with compressor
Jay87T
03-12-2005 11:18:10
just wondering if anyone know what the ratio is for spraying rust paint and primer I think the paint is 2:1 paint/thinner what is it for primer? the same?
Im using a Siphon Feed Spray Gun. any info would be appreciated.
Jay
Mike M
03-12-2005 15:44:02
 Re: question about spray painting with compressor in reply to Jay87T, 03-12-2005 11:18:10
I mix it up so that when you lift up your paint stirring stick you get drips coming off of it instead of a stream of paint. Sometimes I will adjust it thinner or maybe thicker depending on how it's spraying.
CNKS
03-12-2005 11:52:50
There is no standard ratio -- you need to follow the instructions on the can or spec sheet. Primer will not necessarily be the same as the topcoat.
